how do you take out the wiper switch?
Old May 12, 2006 | 10:54 PM
krz6jdm's Avatar
Default how do you take out the wiper switch?
cuz mine only works on the first switch not on the others and it suck when it's pouring out side.
Old May 12, 2006 | 10:58 PM
soslodelsol's Avatar
Default Re: how do you take out the wiper switch? (krz6jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krz6jdm &raquo;</TD></TR><TR><TD CLASS="quote">cuz mine only works on the first switch not on the others and it suck when it's pouring out side.</TD></TR></TABLE>
remove steering wheel
Old May 12, 2006 | 11:05 PM
crxnj's Avatar
its pretty easy to..just pop off the little "h" on the steering wheel with a small screwdriver,,then use a rachet and extension with a 19mm socket and remove the nut thats in there ,,then pull the wheel...and to get off the wiper /turnsignal assembly you'll need a phillips head screw driver..then unplug the wiring clips at the back,,(i use a small flathead screwdriver to get them out)
Old May 12, 2006 | 11:31 PM
Default Re: how do you take out the wiper switch? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">its pretty easy to..just pop off the little "h" on the steering wheel with a small screwdriver,,then use a rachet and extension with a 19mm socket and remove the nut thats in there ,,then pull the wheel...and to get off the wiper /turnsignal assembly you'll need a phillips head screw driver..then unplug the wiring clips at the back,,(i use a small flathead screwdriver to get them out)
what he said also. lol
Old May 13, 2006 | 08:55 PM
krz6jdm's Avatar
Default Re: how do you take out the wiper switch? (soslodelsol)
I'm planning to get it from a 91 hatch would it work on an 88?
94b16teg
Jan 2, 2007 05:50 AM
MurdersV8s
Aug 16, 2006 07:18 PM
PrestonCRX
Apr 23, 2006 11:55 PM
accordredliner
Feb 19, 2006 12:26 AM
SIR Spooner
Mar 8, 2004 07:50 PM
