do you think my Koni's will blow?
Old May 12, 2006 | 09:22 PM
Sleepy_Red_hatch's Avatar
Default do you think my Koni's will blow?
i have koni yellow sports and H&R race springs installed on my car (only in the front till tomorrow morning) my tire is leaving NO gap between the fender and the wheel...do you think this is too low for the shocks to keep up?
Old May 12, 2006 | 10:25 PM
astroxtc's Avatar
Default Re: do you think my Koni's will blow? (Sleepy_Red_hatch)
Bump, I'm going to run this setup soon
Old May 12, 2006 | 10:55 PM
EK4civichatch's Avatar
Default Re: do you think my Koni's will blow? (astroxtc)
They shouldn't blow, the konis can handle upwards up 550lb springs. You may be all over the bump stops though because those springs are pretty low. Be sure not to use the lower perch on the shocks, instead use the "stock" height settings...
Old May 12, 2006 | 10:57 PM
Sean @ ESG's Avatar
My koni yellows are on the low spring perch, w/ ground controls. There is pretty much no choice but to ride low. I've had no problems so far
Old May 12, 2006 | 11:31 PM
turnsignalandy's Avatar
Default Re: (banzai msg)
will driving on bad roads with these shocks increase the chance of blowing, or should it be ok if u drive slow. Im runnig tein stchs and thinkin bout gettin some konis
Old May 12, 2006 | 11:44 PM
Sandmaggot's Avatar
Default Re: (turnsignalandy)
try this, if you can find somone to weld it for cheap. It will let the strut extend a lil more sor you get more use out of it. It shouldnt affect ride, but the strut wont be so compressed.
Old May 12, 2006 | 11:57 PM
E46Kid's Avatar
drive slow, and it should be fine!
Old May 13, 2006 | 04:53 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have koni yellow sports and H&R race springs installed on my car (only in the front till tomorrow morning) my tire is leaving NO gap between the fender and the wheel...do you think this is too low for the shocks to keep up?</TD></TR></TABLE>
Did you install the circlip in the center groove? Do you have at least 1 inch of bump rubber at each corner?
If so, it will be fine.
Old May 13, 2006 | 08:06 AM
Default Re: do you think my Koni's will blow? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
If so, it will be fine.</TD></TR></TABLE>
you know what? i doubt i have a bumpstop.... is it possible there is one hidden under a rubber sleeve?
Old May 13, 2006 | 08:07 AM
lol....scratch that im a total suspension noob, yeah theres a bumpstop, its under this rubber sleeve and i got the setup pre-mounted from a HT user here
this is how low it sits:
a LITTLE higer then that....maybe 0.25" since im on a decline towards the driver's side
Old May 13, 2006 | 08:32 PM
up
Old May 13, 2006 | 09:55 PM
8krdline's Avatar
thats pretty damn low. especially when those are 13s
Old May 13, 2006 | 09:58 PM
EK k kay's Avatar
Default Re: do you think my Koni's will blow? (8krdline)
Looks like you'll ram your lip right into any type of speedbump.
Old May 13, 2006 | 10:01 PM
Targa250R's Avatar
be professional
It's tough to really judge anything from that picture due to the unlevel ground, the close, high perspective, and the wheel/tire combo.
Dude, take a picture of your entire car on level ground with some 15" wheels and 195/50 or 205/50 tires, at about door mirror height. Who knows, it might actually look normal that way
Old May 15, 2006 | 05:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">It's tough to really judge anything from that picture due to the unlevel ground, the close, high perspective, and the wheel/tire combo.
Dude, take a picture of your entire car on level ground with some 15" wheels and 195/50 or 205/50 tires, at about door mirror height. Who knows, it might actually look normal that way </TD></TR></TABLE>
im still looking in my mailbox for you to mail me some rim/tire combo
i cant take full car pics because its been raining and i havent had the chance to do the rear yet so im still OEM lifted in the back....i can make it over SOME speedbumps, the taller ones my lip clears but my exhaust or something hits it on the way down...once i can get the rears on i'll take new pics but i'll still have the 13"s
Old May 15, 2006 | 05:12 AM
.Fez.'s Avatar
hx's are 14's.....not 13s
Old May 15, 2006 | 05:17 AM
Default Re: (.Fez.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Fez. &raquo;</TD></TR><TR><TD CLASS="quote">hx's are 14's.....not 13s</TD></TR></TABLE>
too bad theese are VX's
Old May 15, 2006 | 06:23 AM
ralphie14's Avatar
Default Re: (Sleepy_Red_hatch)
Do the back then look at it. With the back at stock height it is probably putting a lot of "leverage" (not sure the best way to say it) on the front. If you put the back springs in it may even it out and you may get more gap to work with in the front.
Old May 15, 2006 | 07:16 AM
Dwight Schrute's Avatar
Default Re: (ralphie14)
that looks too low for race springs. are they konis with the perches perhaps?
variable
Jul 14, 2008 11:04 AM
88hfef8
Suspension & Brakes
Oct 5, 2006 04:14 PM
Screaming Vtec
Jan 15, 2005 12:40 PM
paulyman
Apr 1, 2002 09:31 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
