Upgrads for a Stock LS Automatic Tranny?
Old May 12, 2006 | 07:36 PM
SLIKKCHICK's Avatar
Default Upgrads for a Stock LS Automatic Tranny?
Ok guys I know that a 5spd is way better and I use to drive nothing but MT. But due to Medical Reasons in my hips, I can not work the clutch peddal. I am wanting to do some upgrades to my 95 LS. I know the stock tranny cant stand up to much more HP then what the engine already puts out. So is there any upgrades I can do to make it stronger? Is there another trany with maby a different gear ratio out there that will work? If not how much more HP can I put on the stock Tranny safely before I Blow the D@mn thing up? Any help would be Awsome! Thanx in advance guys!!
Slikk
Old May 12, 2006 | 07:43 PM
OMG THE GOGGLES's Avatar
Default Re: Upgrads for a Stock LS Automatic Tranny? (SLIKKCHICK)
I would suggest getting (or having done) a modified torque converter for an automatic. Im not an automatic tranny guy, but know how you feel as with my fathers condition of no longer being able to drive a manual car after being in the hospital for a year. My car is manual..but I do have that suggestion for you. Years back I read a write up about it on an accord...it improved numbers in dyno and also increased the idle rpm for a quicker takeoff...no tranny blowing neutral drops needed LOL
Old May 12, 2006 | 07:47 PM
CleanLikeJdm's Avatar
Hype-R Stalker
um.. go buy an auto GSR trans ..
and yes, before you go Ranting off, they DO have auto gsrs, it's not usdm though.
Old May 12, 2006 | 07:54 PM
Default Re: Upgrads for a Stock LS Automatic Tranny? (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">um.. go buy an auto GSR trans ..
and yes, before you go Ranting off, they DO have auto gsrs, it's not usdm though.</TD></TR></TABLE>
LOL single cam integras too. People are so closed minded...to across the seas
Old May 12, 2006 | 07:57 PM
Hype-R Stalker
Default Re: Upgrads for a Stock LS Automatic Tranny? (gasper44`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasper44` &raquo;</TD></TR><TR><TD CLASS="quote">LOL single cam integras too. People are so closed minded...to across the seas </TD></TR></TABLE>
blasphemy!! ..haha yeah it's weird though seeing a sohc in a jdm front teg
Old May 12, 2006 | 08:03 PM
SLIKKCHICK's Avatar
About how much HP would The GSRs AT hold? Also were can I find a aftermarket/custom torque converter?
Slikk
Old May 12, 2006 | 08:10 PM
.brian.'s Avatar
http://www.levelten.com
Old May 12, 2006 | 08:28 PM
SLIKKCHICK's Avatar
Default Re: Upgrads for a Stock LS Automatic Tranny? (.brian.)
Thanx for that Link.
Now If I deside to go with upgrading to a GSR Tranny Would it be a simple swap or is there modifications that will need to be made. And were would be a good place to shop around for The GSR Tranny.
Slikk
Old May 13, 2006 | 08:38 AM
Hype-R Stalker
ah .. well considering it's still an auto, it should bolt right up.
I would think Japan would be a good place to start looking also
Old May 14, 2006 | 02:17 PM
Spec R's Avatar
the auto sir-g is a cool trans, i've heard from 2 old classmates that had them, and they say its a considerable difference. and yes, it bolts right up.
and i'm glad that i got in here before some stupid jerk goes and says "u can upgrade your automatic trans by getting a manual transmission conversion"
middle finger to u if anyone posts something like that...
Old May 14, 2006 | 02:23 PM
RenzoDaPlayboi's Avatar
Default Re: Upgrads for a Stock LS Automatic Tranny? (Spec R)
i have read an article on g2ic.com...that if u buy a new torque converter...and it was one more thing...i cant remember at the time...you will have a strong tranny...they also make b16 auto trannys so think about that too...im sure an auto b16 tranny is easier to find then the auto GSR
Old May 14, 2006 | 03:39 PM
s2kdre's Avatar
Default Re: Upgrads for a Stock LS Automatic Tranny? (RenzoDaPlayboi)
my ls was auto and turbo, it was fast and if u change the fluid it will hold, i swaped it for a 5spd when it had 160k on it, and i was putting out 185whp and 150tq with the auto at 7psi, i dont think u need a better torque converter.
eg2GAMEOVER
Aug 1, 2008 02:41 AM
chris1741
Oct 30, 2006 06:34 AM
B20T CRX
May 22, 2004 10:51 PM
88accordGSR
Nov 27, 2002 07:12 PM
