Go ahead and lowball! EK stuff in Minneapolis. block filler, door shells, more!
FS:
driver side 96-98 headlight with some fogging... $12
96-98 coupe tail lights, full set... $20
Moroso block filler... $18 per jug, I have 2. Each one does about 1 honda block approx,
driver side coupe door shell (red) will come with as many moldings/weather stripping as you want .. $75 -- this door is flawless.
2 white coupe door shells, one has rust all over the bottom, not bad but is a pain... the other has some dents. $FREE and i'll deliver in minneapolis. Otherwise theyre going to the scrap yard soon.
D16y8 head with valves/springs... a cam (not sure if its the right one) and a few other misc things...$30
plastic Saab blow off valve with pipe, worked fine in my car... $10
stock Y8 fuel pump, stock Y8 fuel injectors...$best offer
Stock 96-98 civic airbox/pipe ... $10
D16Y8 crank, slightly scored and will need to be machined.... $15 ...
D16Y8 throttle body w/tps... $25
pictures upon request.
theslugbug
May 21, 2008 11:01 AM
s1ngle
Aug 3, 2006 12:24 PM
