CTR Proportion valve? will it work on 2000 Civic w/ 5 lug?
I have a USDM ITR 5 lug setup that im putting on a 2000 DX coupe, i just found a CTR brake proportion valve. i did a search and nothing came up on this i was wondering if it is the same as the SI one. I cant find any SI proportion valves and just came across this one will wit be direct plug and play?
Just was looking for a quick answer i actually havent looked under my hood yet to see if it matchs at all. i will do that tommorow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">I cant find any SI proportion valves</TD></TR></TABLE>
Si proportioning valves can be easily found. Just buy one from the dealer or http://www.hondaautomotiveparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">you don't need a new prop valve...
just use the one you have
<--- 5 lug EK with stock DX prop valve... works fine
Yeah i know i had a EG i put 5 lug on and didnt use one either, but i heard that with one your pedal will be more stiff
</TD></TR></TABLE>Yeah i know i had a EG i put 5 lug on and didnt use one either, but i heard that with one your pedal will be more stiff
If you are looking for a stiff pedal upgrade the Brake booster and Master Cylinder to the ITR counterparts and you'll feel a big difference.
SS braided lines will also help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">Yeah i know i had a EG i put 5 lug on and didnt use one either, but i heard that with one your pedal will be more stiff</TD></TR></TABLE>
The proportioning valve doesn't affect pedal feel, it affects brake bias.
Mr. Choi
Jun 21, 2004 11:49 AM
