Honda S2000 Honda S2000
Enkei RPF1 info request...
Old May 12, 2006 | 04:36 PM
freeagent32's Avatar
Default Enkei RPF1 info request...
I'm looking to get set of Enkei RPF1 17 x 8 all around with 38 offset all around. My first question is:
1. It's 17 x 8 with 38 offset good for a S2000?
2. What size tires would I need? (Front and Rear)
3. After tires size would I need my fenders rolled?
Please give any info you have. Thanks in advance.
Old May 12, 2006 | 05:20 PM
- BSeRiouS -'s Avatar
Default Re: Enkei RPF1 info request... (freeagent32)
check here, My boy Riley's car...
http://www.s2ki.com/forums/ind...87293
These Are Aggressive, FYI.
Old May 12, 2006 | 05:23 PM
Default Re: Enkei RPF1 info request... (OBSeRiouso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouso &raquo;</TD></TR><TR><TD CLASS="quote">check here, My boy Riley's car...
These Are Aggressive, FYI.</TD></TR></TABLE>
Yea saw it already. Didn't he add to rolled his fenders to get those 18inchs to fit without rubbing.
Old May 13, 2006 | 07:24 AM
dump
What about 17x7.5+48F and the 8.5+40 or 9+35 rear 215/225F 235/245R
What do you guys think?
Old May 13, 2006 | 07:39 AM
-JdmAp1-'s Avatar
you cant get those wheels because thats what i want and when we are at the nh meet we will be twins j/k lol those wheels are sick i say do the 35offset its ballzy but looks mean !!!!
Old May 13, 2006 | 09:43 AM
if i were to run these wheels (i might though) i'd run aggressive offsets because im kew like that.
In order to run those offsets, you will be needing to do a pull on the rears if you wanna run the 8.5 +40 to fit a 245/255. If you want to keep stock body, you might have to give up some patch and run a stretched tire in the rear which will probably be about a 225/235. For the 7.5's, a 215 will probably do you good.
don't think about doing a 9' +35 because that isn't going to work unless you do a super crazy *** pull on the rear, or get wider fenders.
hope that helps.
Old May 13, 2006 | 02:49 PM
pwrofdrm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freeagent32 &raquo;</TD></TR><TR><TD CLASS="quote">dump
What do you guys think?</TD></TR></TABLE>
8.5 +40 in the rear MIGHT work
I'd do 17x7.5 +48 17x8.5 +40. I wanted those for my S2000 but ended up just powdercoating the stocks black. Definately sweet wheels though, I think I might throw them on my project hatch
Old May 13, 2006 | 03:05 PM
Default Re: Enkei RPF1 info request... (-JdmAp1-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -JdmAp1- &raquo;</TD></TR><TR><TD CLASS="quote">you cant get those wheels because thats what i want and when we are at the nh meet we will be twins j/k lol those wheels are sick i say do the 35offset its ballzy but looks mean !!!!</TD></TR></TABLE>
Twins
Well I'm trying really hard to get those by the meet will see what happens.
Old May 13, 2006 | 04:22 PM
Default Re: Enkei RPF1 info request... (.no tork.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .no tork. &raquo;</TD></TR><TR><TD CLASS="quote">
8.5 +40 in the rear MIGHT work </TD></TR></TABLE>
It'll work if he runs a stretched tire. Im pretty sure, a 245/255 won't go in there unless he's rolled. 235 is a possibility. If not, he'll rub.
Old May 13, 2006 | 04:31 PM
hope that helps. </TD></TR></TABLE>
Well, now that i think about it, This is possible. We were able to do a 9.5 + 40 for one of my s2 customers. That should be pretty equivalent to a 9" +35, with about a 1mm difference. All we did was run a 245 + rolled fenders. To be on the safe side, you should add some negative camber while your at it if you run this aggressive of offset. With a little more time and effort, you should look at other peoples wheel set up to get a glimpse of what to look for. Just make sure you know what your doing
Modified by OBSeRiouso at 6:50 PM 5/13/2006
Old May 14, 2006 | 06:16 AM
What do mean when you said: It'll work if he runs a stretched tire.
Old May 14, 2006 | 10:07 AM
Mr. Projekt's Avatar
* B A N N E D *
Running a narrower tire and you usually do. Like putting 245s on a 9" wide wheel. A waste if you ask me, plus there's less protection for the wheel.
Old May 14, 2006 | 10:15 AM
I was browsing and found these pictures from carandmodel. What size do you think his running?
Old May 14, 2006 | 10:36 AM
* B A N N E D *
225/255. How do I know? Those are my fenders.
Old May 14, 2006 | 05:28 PM
Default Re: Enkei RPF1 info request... (FR-MOB: Projekt)
Our customers car.
18x9.5, 18x8.5 + 40 all around.
215 up front. 245 in the rear. Rolled Rear Fenders
Modified by OBSeRiouso at 6:39 PM 5/14/2006
Old May 14, 2006 | 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Running a narrower tire and you usually do. Like putting 245s on a 9" wide wheel. A waste if you ask me, plus there's less protection for the wheel.</TD></TR></TABLE>
Projekt is correct though. The stretched tire look is more for aesthetic reasons. You WILL lose contact patch but i think it looks hard as a mother *****. haha.
I personally like the stretched look. If you see in that pic from the eibach meet, the tires on the silverstone cave in so it doesn't hit the fender. Usually for clearance/Looks. Kinda like this....
Stretched = ( ) ( ) Vs Regualar [ ] [ ]
Modified by OBSeRiouso at 11:27 PM 5/14/2006
Old May 14, 2006 | 05:44 PM
JDM knowledge's Avatar
i have those exact same tires on my S. Those BF Goodrich's run 2 sizes bigger than what they say. ie: a 255 (what i have) is actually a 275. They are auto-X cheater tires. They woudl probably not rub in the back if the tires werent so big and the sidewalls werent so bulgy.
Old May 14, 2006 | 06:55 PM
* B A N N E D *
245 tires on a 9.5 wheel.. now that's a waste. 285/30/18 FTW.
Old May 14, 2006 | 08:33 PM
ITRbroham's Avatar
shit post warrior
I'm sorry, but a lesser width tire stretched over a wider wheel is NOT just for looks!
You ever wonder why you see so many cars that are setup to drift with their tires/wheels in this fashion? A stretched tire is used to prevent tire ROLLOVER and it works quite well. Nothing will make a car understeer like tire rollover. Auto-xers have been doing this for years, although most would prefer the correct size tire with a reinforced sidewall, along with roadracers. Not only does it prevent tire rollover but it's also helps with issues of tire to fender clearance.
Old May 14, 2006 | 10:27 PM
Default Re: Enkei RPF1 info request... (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry, but a lesser width tire stretched over a wider wheel is NOT just for looks!
You ever wonder why you see so many cars that are setup to drift with their tires/wheels in this fashion? A stretched tire is used to prevent tire ROLLOVER and it works quite well. Nothing will make a car understeer like tire rollover. Auto-xers have been doing this for years, although most would prefer the correct size tire with a reinforced sidewall, along with roadracers. Not only does it prevent tire rollover but it's also helps with issues of tire to fender clearance.</TD></TR></TABLE>
Of course. thas understood, But I never said that It <U>WAS</U> just for Looks. Pretty much a high percentage of all the guys that compete in the D1GP have stretched tires and yes they are indeed to prevent tire rollover. I should know, because I have a D1 driver
That being said, thats why soo many people that run stretched tires want to achieve that "IM FLUSHED" look, or acquire tire fender clearance.
Like i stated previously...
Stretched = ( ) ( ) Vs Regualar [ ] [ ]</TD></TR></TABLE>
Old May 14, 2006 | 11:42 PM
* B A N N E D *
I know the purpose of it. I rather have stiff sidewalled tires AND rollover. It will protect my wheel if I do drop it off the track, which I do pretty often anyways, or in a pothole. And I doubt those Do-Luck wheels will ever see an auto-x. I run +1 tire sizing and have never rubbed.
Old May 14, 2006 | 11:51 PM
I know the purpose of it. I rather have stiff sidewalled tires AND rollover. It will protect my wheel if I do drop it off the track, which I do pretty often anyways, or in a pothole. And I doubt those Do-Luck wheels will ever see an auto-x. I run +1 tire sizing and have never rubbed.</TD></TR></TABLE>
and you are correct. im pretty sure it'll never see a day a day at a track with those wheels at all. maybe some spirited driving though.
Old May 16, 2006 | 07:19 AM
I check Enkei again and they make a 16x7 with a +43 offset and I know it's not a good upgrade for an S2000. But what do you guys think of the size and offset?
BTW if I need to go with the 17x8.5 with 40 offset in the rear I found a shop that could rolled my rear fenders.
Old May 16, 2006 | 09:51 AM
16's are very light weight of course and thas a +, but if you plan on running 7's all around, Don't even think about it. Your car is meant for staggered for a reason so degrading it would be a no-no.
If you found a shop that'll roll your fenders, then I say you should take advantage of it. You'll have much more clearance for a fattier tire and your car would be in reccommended contact patch or if not, gain.
Mr. Lucky
Honda S2000
18
May 31, 2005 06:09 PM
GroovyNeilNeil
Honda S2000
13
Oct 14, 2004 10:47 AM
01-0720
Acura NSX
Apr 18, 2004 01:30 PM
v2 Power
Honda S2000
Feb 3, 2004 10:15 AM
red_jdm
Honda S2000
24
Jan 30, 2003 10:38 PM
