power window regulator wiring - problems -
Old May 12, 2006 | 01:39 PM
tomauto's Avatar
Default power window regulator wiring - problems -
Alright, I bought a new window regulator assembly off of e-bay.
When I put it into my door, I pressed the switch to go up...and it wouldn't. So I pressed down thinking it was at its highest point. The motor immedately went down as it should. Then I tried to go up again, and it woudn't move up.
The last one did this also, and I took it to the dealership and they said that my motor was not getting any voltage. So they took out the motor and rigged up window with the cable screwed down to a mounting bolt to keep it up.
The motor is getting power on the down function, but not on the up. What can I do?
Old May 12, 2006 | 01:40 PM
john666's Avatar
Default Re: power window regulator wiring - problems - (tomauto)
maybe the switch for the windows
Old May 12, 2006 | 01:51 PM
tomauto's Avatar
.....Nope, not the switch, it must be something else.
Modified by tomauto at 7:50 AM 5/13/2006
Old May 12, 2006 | 01:54 PM
tomauto's Avatar
I used the switch from the rear door and it had the same adaptor, but it didn't work. (it only made the motor move down, but not up...)
Modified by tomauto at 7:51 AM 5/13/2006
Old May 12, 2006 | 02:10 PM
tomauto's Avatar
need help....look below
Modified by tomauto at 2:21 AM 5/13/2006
Old May 12, 2006 | 02:27 PM
tomauto's Avatar
Alright, the up/down switch it not at fault...the window regulator is new. What else could be the problem?
Modified by tomauto at 1:15 AM 5/13/2006
Old May 12, 2006 | 04:15 PM
tomauto's Avatar
So, I went to a buddy and he said it could be the relay...Where is that on a 1996 Honda Civic LX?
Old May 12, 2006 | 05:22 PM
tomauto's Avatar
any ideas?
Old May 13, 2006 | 08:13 AM
tomauto's Avatar
saturday bump, still need help.
Old May 14, 2006 | 03:35 PM
tomauto's Avatar
where is the window relay?
Old May 14, 2006 | 04:05 PM
tomauto's Avatar
mothers day help anyone?
Old May 14, 2006 | 04:56 PM
hatchi's Avatar
why dont you run another wire with 12volt switched??
1992db2
Jul 21, 2017 05:05 PM
Pauly321
Dec 2, 2016 12:15 PM
da_ska
May 31, 2009 02:32 AM
freeway
Apr 28, 2006 04:26 PM
