Losing Pressure in clutch pedal!!!
Ok so i figured it out. I bleed the clutch slave cylinder.....gets presser back. Cars rides fine. But after a couple of gear changes and pushing in the clutch it starts to lose pressure again. I did this a few times and the same thing happens. Am i bleeding them wrong? Methods you guys use??
What i did:
-I pumped it a couple times and just let the fluid just drain untill all air bubbles were out.
-Re-tighten the bolt.
-Pump clutch again
-Let the fluid drain out
-Retighten
After that the pressure is great!
But after a little bit it slowly loses pressure
Should i be doing/using a different method? Please let me know guys thanks!!
What i did:
-Pump clutch again
-Retighten
scoker83
16
May 12, 2014 07:01 PM
Dukie432
Jun 23, 2009 08:05 PM
