tach is going wild h22 eg
Old May 12, 2006 | 12:58 PM
djsire's Avatar
Default tach is going wild h22 eg
i had a problem with my tach and speedo. i switch clusters and that got rid of the speedo problem. but my tack still does the same ****.
after 4-5 k it goes up and down randomely and i can hear vtec pop in and out.
also i have been having some misses lately. at low rpm.
iv had oil on my plugs before. so i dont kow if thats contributing to the misses? it did in the past.
but what must i do to get the tach workin.
1 more thing. both the dizzy power and tach signal wires are hacked and taped.
i have a extra crx ignitor laying around if thatsa the problem but would it work?
Old May 12, 2006 | 01:46 PM
96-EJ6 B18C's Avatar
Default Re: tach is going wild h22 eg (djsire)
Check the ground on the thermostat housing and make sure it is tight.
Old May 12, 2006 | 02:03 PM
djsire's Avatar
Default Re: tach is going wild h22 eg (96-EJ6 B18C)
cheked its tight!!
it has a bunch of grounds going to it right>
Old May 13, 2006 | 08:38 AM
djsire's Avatar
switched the ignitor for a crx one and i fixed up the wires. the tach works now!!!
however im still gettin the misses in the low end!! im going to get some new spark plugs and tube seals today.
ALSO MY transmission is making whining niose. i know it was loosing fluid before? is that the cause? it also started to grind a lil
Old May 13, 2006 | 02:33 PM
djsire's Avatar
wtf somoen give me input!!
WhiteGsrBeater
Jan 21, 2008 01:08 AM
JasonST
Aug 12, 2006 01:23 PM
force-fed
May 9, 2006 05:05 PM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
Mantis88ls
May 23, 2004 09:13 PM
