pct in a stock b18c5
Old May 12, 2006 | 12:28 PM
integratyper411's Avatar
Default pct in a stock b18c5
Hi to all of you because im new here.
I just put pct's in my 98 usdm itr and I wonder if it should be ok to run them with stock valvetrain. Of course I will get it tuned (probably hondata) at 94 octane but I just want to make sure I wont get any ping.. Sorry if this question sounds newbish to you but ive been trough all the threads and nobody ever talk about them with a stock valvetrain. The only engine mods I have is a full spoon header/exhaust and a cometic bigger than oem size headgasket so my cr ration should be close to 12.2-12.4:1
Thanks
Old May 12, 2006 | 12:35 PM
YumVTEC's Avatar
Default Re: pct in a stock b18c5 (neo_)
the stock ITR valve springs and retainers are just fine, unless you want to rev it higher than the stock rev limit or fuel cut.
you should get some bigger cams (higher lift, longer duration) though to make use of the 1.5-2 full extra points of compression, 10.6:1 to 12.0:1 or higher.
You also need some fuel tuning to compensate for all the extra air you are flowing. I wouldn't recommend pushing it hard on the stock ECU map. you could very well blow it up.
Old May 12, 2006 | 12:37 PM
The cams will be for mid summer. The budget is tight for now. I had to change pistons right now. Back to the topic,
Old May 12, 2006 | 12:45 PM
Dave-ROR's Avatar
Default Re: pct in a stock b18c5 (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">the stock ITR valve springs and retainers are just fine, unless you want to rev it higher than the stock rev limit or fuel cut.</TD></TR></TABLE>
Old May 12, 2006 | 12:56 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Furthor expanding on my analogy. Why would you put such high compression pistions and decide to keep a stock valve train? Put in some good cams that will take advantage of it and actually produce power. BC4, SKP2, M24x, JUN3 come to mind. And of course with such aggresive cams you will need to upgrade your valve springs and retainers.
Edit: Im actually talking about things that don't matter. Nevermind me..</TD></TR></TABLE>
Yes, you are.
But to answer your question, perhaps he needed the pct's to get the car in running condition but doesn't have the money to spend on the cams, springs, etc at the moment.
Plus, you can run stock ITR valvetrain with larger cams (Toda B's, etc), you just don't want to rev it all that high (read: past 8500).
And stock ITR retainers are good for aftermarket cams too. Ti retainers are fine, just inspect them often. I would personally use stock retainers because I'm too lazy to bother with the Ti retainers, even coated.
I'm not telling anyone whether or not they should use Ti retainers, do what you want, but you can use the stock ones just fine.
Old May 12, 2006 | 01:43 PM
Jon D's Avatar
ROR for teh win
Old May 14, 2006 | 07:03 PM
Ok thanks a lot guys for your time. The cams are the next step.. gotta pay university first meh..
Old May 15, 2006 | 05:15 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Im actually talking about things that don't matter. Nevermind me..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Not going to argue with you publically, so I sent you a PM since you like to debate alot. </TD></TR></TABLE>
I mean this in the most constructive way possible:
Stop being such a crybaby bitch. Seriously.
Link16
Apr 18, 2008 05:20 AM
ActiveAero
Dec 5, 2003 02:45 PM
GapxGuy
Feb 12, 2003 10:13 PM
Black R
Nov 25, 2002 09:25 AM
ic108
Mar 8, 2002 07:59 PM
