O2 problem
Old May 12, 2006 | 10:08 AM
hatchish's Avatar
Default O2 problem
Ok i have had this on going problem, i put headers on my b16 everything was fine then about a week later my car started running shitty and threw CEL 1 for the o2. I put a used o2 on, still didn't work, then i got a sohc 4 wire o2, it's brand new i got it for free im running a tuned pr4 computer, do i have to run a twin cam o2 for it to work correctly also on warm days the car runs perfect but still throws a code.
Old May 12, 2006 | 10:27 AM
hatchish's Avatar
bump i need to fix this today!
Old May 12, 2006 | 10:30 AM
snatch's Avatar
Default Re: (hatchish)
I don't believe there is a difference between the SOHC and DOHC O2 sensors. As long as it's 4-wire you should be good.
You reset your ECU right?
Old May 12, 2006 | 10:32 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: (******)
all four wire o2 sensor's are the same. just reset you ecu after you do the o2 swap.
Old May 12, 2006 | 05:53 PM
hatchish's Avatar
ok i reset the ecu that was a dumb move i forgot to do that, but its still throwing CEL 1 and CEL 68 which is a ghost code, im getting pissed i dont want to buy a o2 sensor right now but if i was positive it would work i would get one.
Old May 13, 2006 | 08:40 AM
siregcivic's Avatar
why dont u go back to where u got the ecu done and tell him it keeps throwing the ghost code.. and see if he can fix ur o2 problem
JeffBro
Engine Management and Tuning
14
May 7, 2011 11:04 PM
b18delturbo
Jan 25, 2006 08:16 AM
Mini-mEK4
May 10, 2004 11:05 PM
Rywire
Jan 4, 2003 09:53 PM
