please post your cam timing settings with skunk2 stage2 cams
Old May 12, 2006 | 09:45 AM
darrinbrewer's Avatar
Default please post your cam timing settings with skunk2 stage2 cams
i've got a stock milled head, sotck deck, and cp 11:1s in my gsr, and i'm looking to see others settings so i know from 1 extreme to the other, how far i can go without worrying about valve clearance with each other..
thanks for helping out
Old May 12, 2006 | 09:47 AM
Aquafina's Avatar
Default Re: please post your cam timing settings with skunk2 stage2 cams (darrinbrewer)
Dude, you should've clayed it.
PM vteckidd.
Old May 12, 2006 | 09:59 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: please post your cam timing settings with skunk2 stage2 cams (Aquafina)
Since your head is milled, Advance both cams a degree and leave it there until you get some dyno time.
Old May 12, 2006 | 03:23 PM
Default Re: please post your cam timing settings with skunk2 stage2 cams (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">Since your head is milled, Advance both cams a degree and leave it there until you get some dyno time. </TD></TR></TABLE>
i mean the mill is stock, never been cut, its a portflow p&p head, and the pistons are almost physically identical to itr pistons, not much dome at all.
i'm just looking for a max separation between the 2 cams. i made 181 whp with them on 0-0 and have a perfect idle once warm. i'm not worried about the piston vlave clearance, but more valve-to-valve clearance,
i saw how close the cams brought the valves together in the omni video, only 20thou. between the valves@ overlap.
Old May 12, 2006 | 05:46 PM
DonF's Avatar
!00 deg IN center line. 107 EX. center line.
MikeD21
Jan 26, 2019 09:17 PM
ericrx_88
15
Jun 22, 2010 07:55 PM
all-mtr-teg
Jan 12, 2007 09:25 AM
blowme
15
May 13, 2005 01:31 PM
BlueTeg
Jan 25, 2004 04:01 PM
