HELP! temperature gauge only moves from C to first notch (pic inside)
Old May 12, 2006 | 07:46 AM
huepowered's Avatar
Default HELP! temperature gauge only moves from C to first notch (pic inside)
My temperature gauge has been acting funny. When the car warms up, the highest the gauge will read is the first notch. At that point, my fan turns on. When I drive on city streets (stop and go) the temperature will stay at the line and the fan will turn on, cool down, and turn off. But if I hop on a highway and drive at a constant speed, the temperature gauage goes all the way back down back to the C.
here my fan turns on.. probably the highest i've seen it go.
help a brother out. i searched and found posts on the topic with no replies.
Old May 12, 2006 | 08:24 AM
JimBlake's Avatar
Default Re: HELP! temperature gauge only moves from C to first notch (huepowered)
Could be a bad sender for the temperature gauge. Take it out & put it in hot water with a thermometer. The Helm book (for whatever model & year you're talking about) should give resistance vs. temperature for that sender.
Old May 12, 2006 | 09:47 AM
-DC2-'s Avatar
Default Re: HELP! temperature gauge only moves from C to first notch (JimBlake)
confirm that there is no oil in coolant and vice versa (aka: blown headgasket)
otherwise, i'll bet $$ it's the thermostat stuck open and overcooling
Old May 12, 2006 | 09:59 AM
95DX_D15B's Avatar
I also belive that your thermostat is stuck open. my buddy had the same problem and that was his problem.
Old May 12, 2006 | 11:24 AM
dpetro1's Avatar
Default Re: HELP! temperature gauge only moves from C to first notch (95DX_D15B)
my bet is on the temp sensor. may just be reading wrong. if the thermo was stuck i dont think the fans would ever come on cause the engine wouldnt be getting hot enough.
Old May 12, 2006 | 11:32 AM
JimBlake's Avatar
Default Re: HELP! temperature gauge only moves from C to first notch (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">my bet is on the temp sensor. may just be reading wrong. if the thermo was stuck i dont think the fans would ever come on cause the engine wouldnt be getting hot enough. </TD></TR></TABLE>I agree with this...
Old May 12, 2006 | 12:07 PM
huepowered's Avatar
There's no coolant in the oil. Does the sender have a technical name so I can go buy another one and replace it? Where is the sender in the engine?
For info: I did a compression check 190-180-185-190. 185k miles on the car.
Old May 12, 2006 | 12:17 PM
dpetro1's Avatar
what engine? im assuming b-series, that looks like a teg cluste to me. it is located on the tanny side of the head under the dizzy. i believe there are 2 of them, one is a 2-wire connector which is for the ecu. then there is a 1-wire one that is for the cluster itself. can anyone conform that?
Old May 12, 2006 | 12:20 PM
dpetro1's Avatar
#13 and #11 are the ones i was refering to. thats a pic from an obd1 gsr btw
Old May 12, 2006 | 12:39 PM
huepowered's Avatar
LS motor, would u happen to have a diagram for that? if i knew what the part was called, i could look it up myself, but i do so i gotta rely on u
Old May 12, 2006 | 01:02 PM
JimBlake's Avatar
Here's a '95 LS engine.
Looks like #13 is the 1-wire sender for the gauge in the cluster.
Just FYI, #15 is the temperature sensor for the ECU, while #14 is the fan switch.
Old May 12, 2006 | 07:25 PM
dpetro1's Avatar
damn they are pretty close but not exactly the same. thanks jim, looks like we were both using http://www.acuraparts247.com should be an easy fix, i believe i have a leak from one of my temp sensors so ill be needing to replace some in the near future.
id make sure there arent any other problems with the cooling system before you actually order the part. sounds like everything else is in good shape but i would hate for you to order something you didnt need.
Old May 13, 2006 | 05:53 AM
HondaPartsHero's Avatar
Technical Hero
if you need one of those sensors I'll help a fellow honda techer out and give it to you free, pm me your address and which one of those sensors you need
Littleman456
Nov 14, 2013 05:33 PM
phoenix230197
Jul 12, 2010 12:14 AM
madcivic31
Jan 29, 2010 09:23 AM
JJGagner
Dec 9, 2004 03:58 PM
