Removing lower bll joint from steering knuckle??!?!
Old May 12, 2006 | 07:20 AM
turbotime's Avatar
Default Removing lower bll joint from steering knuckle??!?!
Ok, so i have the balljoints out of the lca's and they are just attached to the knuckles. I have a complete set of new lower balljoints and i cant get the damn old balljoints out for the life of me.
I am talking about removing the bj itself from the knuckle, NOT removing it fromt he lca (already did that). I have the crown nuts off both lower ball joints (knuckle and tierod) but i cant get the balljoint out of the knucle and i cant get teh f'n tierod stud to come out of the knuckle
Does this have to be hydro-pressed out?! HELP
Old May 12, 2006 | 07:26 AM
JDMCivicEF9's Avatar
Default Re: Removing lower bll joint from steering knuckle??!?! (turbotime)
Hammer and a useless old socket thats big enough, roughly almost the size of the balljoint. Just hammer it out and hammer the new one in. Works perfectly.
Old May 12, 2006 | 07:29 AM
turbotime's Avatar
do i need to remove anything from the knuckle itself? like it looks like there is a little lip around where the wheel bearing is that would prevent the balljoint from coming out once its free.
Im guessing you hammer it out fromt he bottom up right?
Old May 12, 2006 | 08:08 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (turbotime)
Okay I just have to ask.... Have you removed the axle from the knuckle? I hope so. There is also a spacer (#2 in bottom pic) between the axle & hub that can get in the way. If it does, just pop it out with a screwdriver. Also make sure the spacer goes back in all the way when you reinstall it...
Supposedly there is a balljoint press tool (see below) you can rent at Autozone for free. You just setup the cups properly and press the old balljoint up through the knuckle (towards where the axle used to be). You can also try the Big-Fukin-Hammer method that many people perfer.
Also, most balljoints use a large snap-ring (#24 in bottom pic) to keep the balljoint from ever backing out, so make sure that is not present when you try to remove it. If you don't, you'll get nowhere fast...
meanshyguy
Jun 5, 2010 09:32 AM
RaCk
20
Jan 14, 2006 09:17 PM
89crx23
Jun 24, 2005 07:24 AM
ice11honda
Aug 30, 2004 05:50 PM
klepsta
27
Apr 29, 2004 01:31 PM
