ignition buzzer
hello fellow crx fans, I have a'88 crx hf that i have been slowly restoring, mechanically things are good, the body has the usual rust spots. My problem is that I can't put the keys in the ignition, turn the key to the acc position without a buzzer driving me crazy. Can anyone tell me how to disconnect this buzzer and will the disconnection cause any other problems?
thanks
hondahak
thanks
hondahak
If the buzzer is sounding because you have the key in the ignition and the drivers door is opened, just disconnect the door switch. This will have the effect that the door is closed, shouldn't bother anything.
oes
Dec 9, 2003 06:38 AM
