calipers
I was wondering if anyone out there know if there is a difference between 91 honda crx si rear calipers and 90-93 integra rear calipers. also if there is a difference between 89 honda civic front calipers and 90-93 integra front calipers.
Would I be able to use integra calipers with no mods on my civic.
As for the rear calipers they are the same. I swapped them on my 91 without any problems. the 89 civic and 90-93 fronts are very different though. If you want to use the integra calipers you will need the bracket for them and the correct steering knuckle. Most seem to prefer the 91 civic ex knuckles but you can get away with the 90-93 integra (get an alignment NOW!). Further note that your front brake lines will work but the integra ones will be better (slightly longer). Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elchapin »</TD></TR><TR><TD CLASS="quote">I was wondering if anyone out there know if there is a difference between 91 honda crx si rear calipers and 90-93 integra rear calipers.</TD></TR></TABLE>
They are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also if there is a difference between 89 honda civic front calipers and 90-93 integra front calipers.
Would I be able to use integra calipers with no mods on my civic.</TD></TR></TABLE>
They are completely different. You need to swap the entire knuckle to use the '90-93 Integra rotor and caliper on an '89 Civic.
They are the same.
91CR-XSiR
Jul 25, 2007 11:03 AM
g2turbo
Jun 21, 2005 07:52 AM
jpb105079
Aug 19, 2004 11:08 AM
