Mating a GSR crank with a B16a JDM block./
Old May 11, 2006 | 09:41 PM
b16nonoy's Avatar
Default Mating a GSR crank with a B16a JDM block./
Is this possible? I have heard the the pistons will stick out of the top of the block and risk hitting your head or spark plugs?
I have recently bought 9.8 84mm JEs but I want to stay all motor but want to stroke my B16a to 1.8L and get high compression pistons.
Old May 11, 2006 | 10:06 PM
UncleD's Avatar
Default Re: Mating a GSR crank with a B16a JDM block./ (b16nonoy)
It is possible yes, but custom rods and pistons would have to be made. Normally when people stroke a B16a they use the B17 crank...also known as the Tech43 kit.
Old May 12, 2006 | 04:56 AM
SkRiBLaH's Avatar
Default Re: Mating a GSR crank with a B16a JDM block./ (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">It is possible yes, but custom rods and pistons would have to be made. Normally when people stroke a B16a they use the B17 crank...also known as the Tech43 kit.</TD></TR></TABLE>
wrong.
the tech 43 kit is a set of custom pistons with a raised wrist pin. you use LS crank and LS rods. =1.8xx L (almost 1.9 with the 82x89)
the b17 crank and rods is a completely different thing. =1.7L
Old May 12, 2006 | 05:20 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Mating a GSR crank with a B16a JDM block./ (SkRiBLaH)
You can stroke a b16a with B17 internal components ie rods and crank.
chuisek9
Apr 15, 2008 06:08 PM
Bsixteen_CRX
33
Nov 26, 2007 07:42 PM
Bsixteen_CRX
Sep 30, 2007 08:10 PM
spoonek4
Oct 13, 2002 06:40 PM
BoostedSi
Apr 25, 2002 01:50 PM
