gas emissions....
Old May 11, 2006 | 08:00 PM
vandersmissenc's Avatar
Default gas emissions....
ok well before im flamed as a noob, i searched and read a bit before asking this.
i failed inspections so i got my new exhaust system , now tommorow im going back to test again. Should i run 93 octane or 89 octane ? when i took the test the first time my OH was high my CO was high and my NOx was high, but i had 1" piping with no cat. now i have 2.25" piping a high flow cat and a muffler from wicked tuning. this is all on a b16.... which gas octane should i run to help pass emissions ?
TIA
i was thinking that because higher octane burns cleaner 93 would be good right ?
Old May 11, 2006 | 08:09 PM
Default Re: gas emissions.... (vandersmissenc)
bump comon please
Old May 11, 2006 | 08:10 PM
axtran's Avatar
i heard the lower you get better on smog tests.
Old May 11, 2006 | 08:11 PM
Default Re: (axtran)
so like i should fill up on 87 ? or 89 ?
Old May 11, 2006 | 08:12 PM
axtran's Avatar
is the motor usdm or jdm? i heard on JDM you should go as high as possible to not risk dmging ur car..
Old May 11, 2006 | 08:13 PM
axtran's Avatar
plus the fact that you had no cat... that's illegal in all 50 states! course you'd fail! i say just stick with 91 and test again, with a cat you'll most likely pass.
Old May 11, 2006 | 08:14 PM
ok , it's JDM and i got a high flow cat but before i didn't have one, i never got under and looked, i just put the stock emission for the CX back on after engine swap because i had no money for exhaust yet. Stock CX didnt have a cat on it lol.
Old May 11, 2006 | 08:21 PM
axtran's Avatar
yeah cx's cat is on the header. its weird, and extremely ghetto. you should be set with that cat.
Old May 11, 2006 | 08:34 PM
thanks for the help you are an A++ H-T member
jt2008
Jan 29, 2015 04:14 PM
fongph
29
May 24, 2006 08:50 AM
redlinenprelude
May 13, 2004 04:32 AM
spettinger
Aug 30, 2002 04:26 PM
