clutch ?'s
Old May 11, 2006 | 07:56 PM
speedysohc's Avatar
Default clutch ?'s
i have a del sol si w/ i/h/e
i need a clutch but not sure what kind to go with
what stage?
i don't want to get a clutch thats to powerful 4 my car.
keep in mind im not boosting anytime soon money isnt there
also should i get a lighten flywheel or just get it recut
what kind?
Old May 11, 2006 | 07:59 PM
peacexisxfree's Avatar
Default Re: clutch ?'s (speedysohc)
a stock clutch will be quite fine. leave the flywheel as is. with a stock motor, it won't do ****.
Old May 13, 2006 | 09:11 PM
speedysohc's Avatar
oem clutch... sounds good thnx man
Old May 13, 2006 | 09:41 PM
efb16's Avatar
Default Re: (speedysohc)
if your not going turbo or anything just buy a clutch from National auto parts or something, if you have them there. Cheapest damn clutches that get the job done. if anything i hope this helps
Old May 14, 2006 | 02:19 PM
speedysohc's Avatar
yea probably just gonna shop around and see whats up thnx for the suggestion... ill be sure to check it out
Old May 14, 2006 | 05:31 PM
Dilly's Avatar
the exedy street clutch is good. i have in my car. works good.
Old May 14, 2006 | 07:18 PM
speedysohc's Avatar
will that be to heavy of a clutch for an n/a sohc?
Old May 14, 2006 | 07:25 PM
Runnerdown's Avatar
either oem replacement exedy or the stage 1. The oem might be a bit soft for the agressive driver but will hold your power fine.
Old May 14, 2006 | 07:26 PM
lv6l's Avatar
not much people go NA with sohc. they go NA with DOHC. with sohc its best if you boost. but if you doing nither of that, use any stock type clutch is fine. ebay has some for your motor for about 50 bucks with pressure plate, disc, throw out bearing, and pilot bearing. great deal.
Old May 14, 2006 | 08:06 PM
speedysohc's Avatar
would LOVE to boost but money isnt there hell ya ill check that out thnx
renyay
Honda CR-V & Element
Aug 4, 2017 08:54 PM
jwhezzy2003
Aug 28, 2008 08:46 AM
cbmprelude
11
Apr 27, 2006 08:39 AM
Nightscape
May 17, 2004 01:17 AM
Toretto
Feb 25, 2003 08:51 AM
