Hondata S300 Questions?
Old May 11, 2006 | 06:34 PM
K-Spec's Avatar
Default Hondata S300 Questions?
I have a p28 w/ hondata s300 and I want to put this in. My question is do the s300s have preset settings (for a/f ratio, fuel mapping, etc.) that I can select from or do I have to set them myself? Would it hurt my engine to run with it for now w/out having to tune it? I'm gonna tune it later after I have all the parts installed.
Old May 11, 2006 | 07:09 PM
CivicSiDriver02's Avatar
Default Re: Hondata S300 Questions? (khalal538)
I believe that there are settings for common combinations. I would just street tune it if you have the time. Just set your tune on the rich side and you should be fine until you can get the rest of your parts installed along with a dyno tune.
Old May 11, 2006 | 07:41 PM
98vtec's Avatar
moderator emeritus
Default Re: Hondata S300 Questions? (CivicSiDriver02)
doesnt s300 have autotune?
Old May 11, 2006 | 08:59 PM
PrecisionH23a's Avatar
Default Re: Hondata S300 Questions? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">doesnt s300 have autotune?</TD></TR></TABLE>
Yes... but in my opinion auto tune is a waste of time. It doesn't automatically set itself to the settings you want. It takes more time than a click of the button to calibrate everything.
You have a couple of maps to choose from that should get you up and running if you are running stock injectors. If you have anything other than stock as far as injectors or upgrades then you will need to modify your fueling and ignition tables accordingly.
Old May 11, 2006 | 09:04 PM
K-Spec's Avatar
Default Re: Hondata S300 Questions? (PrecisionH23a)
ok thnx guys. i'm gonna plug it in tonite.
MOVE OVER
Jul 12, 2006 01:13 PM
JDM MonopolyMan
Dec 10, 2005 07:37 PM
dc2turbo
Jan 22, 2005 03:43 PM
inda14s
Jul 19, 2004 08:00 AM
blykins
Jul 17, 2003 09:13 AM
