how much do you guys think this engine is worth!?!? help me out
Old May 11, 2006 | 05:12 PM
greddy13's Avatar
Default how much do you guys think this engine is worth!?!? help me out
its a totally refreshend single cam with a si vtec head and si bottom end, si tranny, has a bullfrog cam, b16 mani/tb and b16 injectors.. AEM fuel rail/regulator
Old May 11, 2006 | 05:44 PM
hyperforming's Avatar
1000 tops. what modification did you need to do to put a b16 manifold on a d16 head? i am interested if it is bolt on thanks
Old May 11, 2006 | 05:46 PM
Default Re: (hyperforming)
1000 cause i could get them cheaper but yours is rebuilt i probably will pay 400-450 for entire swap d16z6 axles linkage tranny but high miles like 140k rebuilt is worth the extra $
Old May 11, 2006 | 05:52 PM
greddy13's Avatar
its bolted right up, i only paid 500 bucks for it today
Old May 11, 2006 | 06:45 PM
b18sihatch's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (greddy13)
that manifold looks just like the y8 and i believe the manifolds dont bolt up so its prolly a y8 mani
Old May 11, 2006 | 07:13 PM
greddy13's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (b18sihatch)
well was it worth the 500 bucks
Old May 11, 2006 | 07:52 PM
b18sihatch's Avatar
i would say it is a good price, as lonf as all the compression is up and good and nothing leaks and everythnig then 500 is good
Old May 12, 2006 | 02:51 AM
k24ej8's Avatar
yup y8 mani.. not bad price concidering the fuel rail
Old May 12, 2006 | 12:21 PM
b18sihatch's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (k24ej8)
fuel rail is worth a good 100+ so that is definitly a good deal
Old May 12, 2006 | 01:22 PM
trickeng's Avatar
$500 is a good deal. junkyard SOHC VTEC's sell for $750-$900 in the northeast.
Old May 12, 2006 | 03:52 PM
k24ej8's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (trickeng)
how much? i got my k20a2 for $900 at the junkyard
Old May 12, 2006 | 05:54 PM
JDMCivicEF9's Avatar
800 the most I'll pay.
Old May 12, 2006 | 06:49 PM
greddy13's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (JDMCivicEF9)
it has a bseries mani and im suppose to switch the wires on the map senser and plug it into the tb? idk wich wires to change around. do eny of you?
Old May 12, 2006 | 10:40 PM
EJ8tunerman's Avatar
Its not a b-series intake manifold. Its an intake manifold off of a 96-00 Civic ex w/ a d16y8.
Old May 12, 2006 | 10:54 PM
greddy13's Avatar
Default Re: how much do you guys think this engine is worth!?!? help me out (EJ8tunerman)
ok well then a ex mani
Old May 13, 2006 | 04:12 AM
b18sihatch's Avatar
d16y8 manifolds are like the type r of d16
Old May 13, 2006 | 07:28 AM
Its evidentally A manifold off of an AUTO Ex/y8, because the Idle air control valve is located on the throttle body. When converting the 3 wire IACV to the 2 wire IACV, you must also switch a pin on the ECU, so you may have to switch one also, only vice versa.
SOHC_civic_si
Jan 28, 2009 03:37 PM
AJxr
Jan 19, 2006 07:49 PM
JDMKid71
Jun 30, 2005 07:42 PM
Smith Wise
Apr 15, 2003 05:00 PM
CYBEREXII
Jan 9, 2003 02:47 PM
