can you run a 90degrees silicone coupler off the turbo??????
Old May 11, 2006 | 04:41 PM
1slowcrx's Avatar
Default can you run a 90degrees silicone coupler off the turbo??????
i was wondering can you run a 90degrees silicone coupler off the turbo. would it hold up to the pressure coming off the turbo or would i have to run something metal to run a 90 off the turbo? will it withstand high boost?
Old May 11, 2006 | 04:48 PM
ichbinsobose's Avatar
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (1slowcrx)
I run one, and its not even a real coupler I don't think. You'll be fine.
Old May 11, 2006 | 04:49 PM
Bailhatch's Avatar
Some people say that a sharp bend out of the compressor an help flow by 'knocking the spiral' out of the flow and letting it become laminar sooner. Im really not sure if this is true.
If anything, at least it's before the intercooler so the turbulance induced heat could be dealt with.
Old May 11, 2006 | 05:22 PM
coneheadsracing's Avatar
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (Bailhatch)
a smoother longer 90 would be the way to go, for air flow. However, sometimes you have to do what you have to do. I don't see any issues with it personaly.
Old May 11, 2006 | 05:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
cant be any worse than a back door intercooler. as long as it is a good coupler, you should be fine.
primeredbeast's Avatar
it worked fine for me just keep in mind that if the piping moves any it may kink the airflow some if your piping isn't secured real well just something to keep in mind
Old May 11, 2006 | 05:33 PM
1slowcrx's Avatar
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (primeredbeast)
i'm just worry that a sharp 90 off the turbo mite not hold up in high boost. from what i read, i think i will be fine. it's a good quailty 90 from samco.
Old May 11, 2006 | 05:35 PM
HamiltonRex's Avatar
It will be fine!
Old May 11, 2006 | 05:44 PM
Weq's Avatar
Weq
Well actually u might run into issues like we did. Silicon 90's cause alot more flex then usual.
A silicon bend will heat up and become alot more flexable. What happened with ours is that is was flexing under high boost (17~psi) and because of the 180bend at the intercooler, was pushing itself apart. This flex would not have happened with a metal 90 bend.
That said, if u use good silicon and tbolts/heavy duty screw clamps and lipped piping, you shouldnt run into trouble.
Old May 11, 2006 | 05:56 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
you will be ok with it.. hell my charge pipe is like a 180 out of the turbo and never had a problem with it blowing off.. just get some t-bolts
Old May 11, 2006 | 06:09 PM
TurboEM1's Avatar
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (1QwIkEf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">cant be any worse than a back door intercooler. as long as it is a good coupler, you should be fine.</TD></TR></TABLE>
can you elaborate? i am looking to buy a full race intercooler.
Old May 11, 2006 | 06:12 PM
platinum00's Avatar
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (TurboEM1)
as other said you will be fine. the bigger the 90 is the better. try and make it 2.5'
platinum
Old May 11, 2006 | 06:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: can you run a 90degrees silicone coupler off the turbo?????? (platinum00)
I used a 2in-2.25in rad hose from NAPA and its held up to 19psi with a 90 deg. bend very similar to the pic above. Holds 15-16psi daily, no problem.
Blaze
v.i.gsr
Jun 17, 2011 08:38 AM
szczerbanator
Jul 10, 2009 11:47 PM
93boostludeSi
Apr 23, 2007 09:49 AM
vladd
Jan 26, 2007 08:21 AM
92hatch420
Feb 20, 2006 02:03 AM
