Receiver Dryer
Old May 11, 2006 | 04:16 PM
1990AccordEX's Avatar
Default Receiver Dryer
i was told that both the A/C compressor and the receiver dryer needed that special oil added to both of them. All i need to know is how much oil goes into both of them. Thank You for your help!
Old May 11, 2006 | 06:21 PM
Default Re: Receiver Dryer (1990AccordEX)
how do you drain and refill the a/c compressor
and fill the receiver dryer
Thank again
Old May 11, 2006 | 08:37 PM
ricebike's Avatar
u still have R12 or was it retrofitted w/ R134A?
fill the receiver/drier???? wha???????????????????
if it's still a closed system. it can be done w/ very expensive specialized equipment...
take it to the shop for this unless you have the vaccuum pump to evacuate the refrigerant & oil to measure how much u have "pulled out" from the system
if it's already apart & you're replacing w/ new compressor, then add the proper amount to the compressor only/ not to the receiver/drier.
either way, you'll need that vaccuum pump to make sure your system is "dry" & sealed before recharging...
Old May 12, 2006 | 04:05 AM
YeuEmMaiMai's Avatar
Default Re: (ricebike)
for long service life you want to make sure that it can hold a vaccum for at least 12 hours. If it cannot, find the leak(s) and fix them. The only time a receiver dryer should be repalced is if the following are true
1. System was opened up for repairs (IE they replaced a line, compressor, etc)
2. IF the system was converted to r134a from r12 (pre 1994 cars only)
3. Your compressor has failed and metal crap has been sent through the system (usually gets trapped at the "H" expansion valve. So see #1 above.
Old May 12, 2006 | 06:59 AM
snyderman5's Avatar
The reciever drier is a filter that takes acid out of the a/c system. Its very common to put one in after a compressor has failed.
Old May 12, 2006 | 08:47 AM
Ross 2.0's Avatar
In a Junkyard near you.
Anytime the system is opened I reccomend replacing the drier. WHat you can do is drain the old from replaced components and add the same amount of new oil to the new component.
And changing the oil with an R-12 to R-134A conversion is not required (as long as the oil is not contaminated with metal or other inpurities)
Old May 13, 2006 | 10:36 AM
ricebike's Avatar
Default Re: (snyderman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snyderman5 &raquo;</TD></TR><TR><TD CLASS="quote">The reciever drier is a filter that takes acid out of the a/c system. Its very common to put one in after a compressor has failed.</TD></TR></TABLE>
yup i know that, but u don't put oil in the receiver/drier... just to the compressor or if it's still in a closed/sealed system... injected thru the machine
if compressor failed, highly suggest getting an inline filter as well to catch any metal particles floating around... even after a flush, some may linger in there
Old Sep 1, 2009 | 02:51 PM
b737c's Avatar
New User
is the receiver drier fairly easy to get to. can it get pretty plugged up...my high side pressure is high and the low side is really low...plugged drier?
Rick1t
May 6, 2013 06:03 PM
Gigem891
Jun 22, 2011 08:11 AM
8083tcman
Oct 27, 2008 11:36 PM
JBirch_97Prelude
Jun 7, 2008 02:32 PM
dchi_t
May 8, 2003 10:00 AM
