Hf engine harness on 91 b18... problems.
Old May 11, 2006 | 03:10 PM
tek_civic's Avatar
Default Hf engine harness on 91 b18... problems.
so im converting a obd-0 88 HF engine harness to work on a 91 b18 (obd-1) the problem im running into is this. IM one plug short!! i have all the plugs accounted for, moved the fan switch wires, changed the injector plugs, removed the resistor box, adapted the distributor, everything.
on the b18 there is one little 2 wire "snap" plug on the back of the block next to the oil filter, it looks like it goes into the water jacket. at first i thought it was the thermo switch, but i already have two plugs that are coolant related(thermo switch, and temp gauge i believe). so whats this last plug?
if anyone has done this conversion before did you have any spare plugs or anything like that? this is the last thing i need to solve before i put her in the crx.
thanks a bunch!
Old May 11, 2006 | 03:33 PM
tek_civic's Avatar
im really regretting not buying a 90 b18. lol im an idiot
Old May 11, 2006 | 06:15 PM
Rywire's Avatar
Default Re: (tek_civic)
that greenplug on the back is not used
Old May 11, 2006 | 06:19 PM
Bjorn20's Avatar
why are you regretting not getting a 90 ls? to my knowledge the 90 and 91 ls's are the same
Old May 11, 2006 | 07:29 PM
d16vtecx's Avatar
Default Re: (Bjorn20)
a 91 ls is obd0
the hf harness will have an extra plug for the EGR sensor that the ls motor doesnt have
all the other plugs should match up
Old May 13, 2006 | 03:50 PM
tek_civic's Avatar
Default Re: (d16vtecx)
ooops i meant 92. i wated a 91, but ended up with an obd1 92 b18. oh well, when all is said and done ill be happier with the obd1
thanks for the help
crxnatic
Feb 1, 2019 07:25 AM
july88crxhf
Jan 9, 2010 08:32 AM
93civiceg6
May 30, 2006 11:40 PM
riceboyEFsi
Jun 7, 2003 12:16 PM
