Cheap brake master cylinder vs higher priced?
Old May 11, 2006 | 03:03 PM
Voodooboy520's Avatar
Default Cheap brake master cylinder vs higher priced?
Anybody have any experience with the cheaper or more expensive master cylinders that are not Honda? I have a DX, honda wants 160 for a new one.
http://www.partsamerica.com/Pr...set=A - Less expensive
http://www.partsamerica.com/Pr...set=A - More
The more expensive is a 1 year warrantee, cheaper is limited lifetime. I dont want a remanifactured, **** always goes wrong with them.
Old May 11, 2006 | 06:18 PM
bump-o
Old May 11, 2006 | 07:35 PM
Crx Jimmy's Avatar
Default Re: Cheap brake master cylinder vs higher priced? (Voodooboy520)
the cheaper one looks like a better deal, and a better part, both are name brands so i wouldnt worry
Old May 11, 2006 | 07:42 PM
downest's Avatar
Default Re: Cheap brake master cylinder vs higher priced? (Crx Jimmy)
All the new and reman Honda MCs I've seen are Nissin anyway, regardless of what the store says.
Old May 12, 2006 | 11:24 AM
Now, just to make sure its the master cylinder, I'd like a second opinion. When I sit at red lights (or when I have the brakes pressed for more than a coupple seconds) the pedal slowly creeps to the floor. The big black rubber boot on the brake booster is also kinda flaking because it looks as if the master cylinder is leaking fluid. Sound like my diagnostic is correct?
Old May 12, 2006 | 11:34 AM
WolfGod's Avatar
Default Re: (Voodooboy520)
the only times i've ever had MC's go bad, i'd have perfect peddle pressure at idle, but as soon as i start driveing my pedal goes to the floor and requires pumping to stop
my third one just went bad two days ago.. make sure to bleed the **** out of your brakes after installing the new one
Old May 12, 2006 | 11:42 AM
downest's Avatar
Default Re: (WolfGod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">Now, just to make sure its the master cylinder, I'd like a second opinion. When I sit at red lights (or when I have the brakes pressed for more than a coupple seconds) the pedal slowly creeps to the floor. The big black rubber boot on the brake booster is also kinda flaking because it looks as if the master cylinder is leaking fluid. Sound like my diagnostic is correct?</TD></TR></TABLE>
That's what mine did too. You're losing fluid somewhere, if you can see it leaking around the MC, you should replace it.
Old May 12, 2006 | 02:25 PM
WolfGod's Avatar
Default Re: (downest)
you dont have to be looseing fluid for it to go bad, i didnt have a single leak in my entire brake system when mine went bad
$60 for the MC isnt that bad and it takes less then half an hour to install if you know what your doing
Old May 12, 2006 | 02:42 PM
downest's Avatar
Leaking is a sure sign though. Mine wasn't leaking externally either, but the seals weren't holding the fluid in.
shadohconspiracy
13
Sep 27, 2007 10:09 PM
xavior66
Oct 18, 2006 12:11 AM
integra123
Aug 8, 2006 05:52 PM
92integraVTECgsr
Oct 26, 2005 05:17 PM
