RODS, opinions on high rev
Old May 11, 2006 | 02:04 PM
SIred91's Avatar
Rainman
Default RODS, opinions on high rev
Looking for people who have BUILT a D series to hold up to 8500+ rpm blasts.
what rods do you use?
for that matter, what valvetrain and piston/rod combos are used?
I'm in the process of a teardown and major build of a sohc ZC.
So if any of you have done this please share info, thanks.
save the bench racing for the bench,
im looking for actual experience.
searched to no avail thus far.
Old May 11, 2006 | 02:09 PM
93-lsvtec-eh2's Avatar
Default Re: RODS, opinions on high rev (SIred91)
i'm not 100% sure but wouldn't you be able to use a nice forged rod form a ls motor. if so you have tons of options
Old May 11, 2006 | 03:22 PM
ExospeedAMcrx's Avatar
we've built a good number of D-series setups.
If you really are plannign to take the RPMs up that high, I would invest on an aftermarket rod such as Eagle Rods. the key is the rod bolts in these things.
Another suggestion is also stock rods but with ARP rod bolts. But to really make these work, you have to shot peen them as well and the price for that plus the ARP rods is close to getting aftermarket rods already.
at 8500 rpm. dont do it unless you go Eagle rods.
Old May 11, 2006 | 04:35 PM
SIred91's Avatar
Rainman
Default Re: (exospeedAMcrx)
what about higher? would eagle handle it?
ive got a p+p head with skunk2 goodies and p+p matched intake.
I plan on using a pretty stout dual stage nitrous setup.
Old May 11, 2006 | 04:53 PM
Default Re: (SIred91)
Yes the eagle rods can handle that much rpm. but the skunk2 valvetrain is what I would question. Make sure the valvetrain has the right spring rates for what you are using it for.
I've taken the Supertech setup to 9500rpm All Motor.
Old May 12, 2006 | 01:01 PM
SIred91's Avatar
Rainman
Anyone else with high rev (above 8500) experience?
Bisi? you out there?
Old May 14, 2006 | 01:00 PM
SIred91's Avatar
Rainman
bump, thread, not valves. lol
Old May 14, 2006 | 06:21 PM
d16dcoe45's Avatar
I run up to 8600 rpm on Eagles on my a6--the old ones with the 5/16" cap screws...
Old May 15, 2006 | 09:03 AM
SIred91's Avatar
Rainman
Default Re: (d16dcoe45)
cool, how is your a6 set up? boost? nitro? how are you hitting and making power at 8500?
haters909
Jun 10, 2012 10:01 PM
SIred91
10
May 13, 2006 09:30 AM
johncarlos
May 1, 2004 02:51 AM
94B18B1Teg
Feb 10, 2004 11:03 AM
Big Teggie
15
Sep 8, 2003 12:57 PM
