removing butterfly from Intame manifold good or bad?
Old May 11, 2006 | 01:51 PM
allaboutdaz's Avatar
Default removing butterfly from Intame manifold good or bad?
will removing the butterfly inside the intake manifold benefit at all?
good or bad?
i am thinking of doing this on a 97 prelude
has the basi bolt one cai, exhaust, header, test pipe
thanks
Old May 11, 2006 | 02:38 PM
SuperSlow's Avatar
Default Re: removing butterfly from Intame manifold good or bad? (allaboutdaz)
for your listed mods, it will probably cost you a little bottom end....
Old May 11, 2006 | 02:43 PM
Default Re: removing butterfly from Intame manifold good or bad? (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">for your listed mods, it will probably cost you a little bottom end....</TD></TR></TABLE>
any gains?
and what needs to be done to remove?
Old May 11, 2006 | 02:56 PM
SuperSlow's Avatar
If you are really set on losing bottom end, go search for it (red "search" in top right).
Old May 11, 2006 | 02:58 PM
98vtec's Avatar
moderator emeritus
If you are really set on losing bottom end, go search for it (red "search" in top right). </TD></TR></TABLE>
not enough loss to make a difference. My bottom end is peppier than ever and i have the IAB's out. If you remove them, there are ways to tune around the supposed low end power loss.
Old May 11, 2006 | 03:01 PM
Default Re: removing butterfly from Intame manifold good or bad? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
not enough loss to make a difference. My bottom end is peppier than ever and i have the IAB's out. If you remove them, there are ways to tune around the supposed low end power loss.</TD></TR></TABLE>
any more info on tis?
nice gains?
write up maybe?
Old May 11, 2006 | 03:04 PM
2lude4u's Avatar
https://honda-tech.com/zerothread?id=1250755
Old May 11, 2006 | 03:06 PM
98vtec's Avatar
moderator emeritus
what writeup? lol
all i did was unscrew the valves from the shaft. The shaft is still in there. Probably disrupting the air flow, but who cares...i got something better to replace it.
there arent any gains. I'm running a p28 which doesnt control them and i didnt feel like ******* with the ecu just to get them to work.
Default Re: removing butterfly from Intame manifold good or bad? (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1250755</TD></TR></TABLE>
thanks for that link
anymore help is appreciated
Dartanian
Jul 6, 2006 02:29 PM
IE_EG8
Jan 10, 2005 04:39 AM
dukduk
Welding / Fabrication
Dec 2, 2004 11:39 PM
AllMoToRB18c
Oct 30, 2003 11:45 AM
crx(gator)
Jul 25, 2003 10:41 AM
