Steering shakes between 90-110 kph
Old May 11, 2006 | 01:14 PM
ImPuLsIvE's Avatar
Default Steering shakes between 90-110 kph
Alright. I got some new rims late last week (18x7.5 Konig Tuner 2's w/ Hankook K104 225/35/18 tires) for my '94 Prelude SR-V, and ever since then my steering has been shaking when I'm going between 90kph and 110kph. Now, of course I figured this was a wheel balance issue, and since I received the wheels with the tires already mounted and balanced, I paid to have the rims balanced a 2nd time by a 3rd party shop. Turns out two wheels were off balance (Driver's front & Pass rear). I put the wheels back on the car and hit the highway. Same problem persists. I ask my friend who did the balancing if he could of done it wrong, where he assures me he balanced them perfectly. He recommended that the Hub-Centric Rings that were supplied with my rims could be wrong. So I pulled the wheels off the car (again) and checked the rings.. They fit perfectly to my hub and were snug on the rims. I put the wheels back on and tightened the lugs per spec (80 ft/lbs). Hit the highway again, problem STILL persists.
This problem never happened to me with my old rims (17x7 Enkei Evo 6). So I highly doubt it's my car. I checked to see if there was any play (up/down, left to right) on the mounted rim to check the CV joins, etc.. But there's no play what-so-ever. I've been given the advice to replace all the hub centric rings, as they could be slightly off (even though they don't seem to be from my visual inspection). But I have no other clue as to what could be doing this.
Any help would be greatly appreciated.
Thanks!
Old May 11, 2006 | 01:48 PM
chitownrida's Avatar
sounds like hubcentric rings if anything
have you had the car aligned lately?
Old May 11, 2006 | 02:38 PM
SuperSlow's Avatar
Default Re: Steering shakes between 90-110 kph (ImPuLsIvE)
alignment. git er done.
Old May 11, 2006 | 03:35 PM
ImPuLsIvE's Avatar
Alignment is about the only thing I haven't done thus far. I didn't think it would create that kind of symptom, but maybe it does?
I'm going to be getting new Hub Centric Rings from the Company I got the wheels, just to eliminate it as a possibility. If the symptom still persists after getting the rings replaced, I'll go for an alignment.
Old May 11, 2006 | 04:24 PM
roller3804's Avatar
bent rim?
Old May 11, 2006 | 06:34 PM
ImPuLsIvE's Avatar
Default Re: (roller3804)
Any defect in the tire/wheel would of been shown during the 2nd alignment... Or so I've been told. So I don't think the wheels/tires themselves are defective in that aspect.
Old May 12, 2006 | 06:35 AM
satsilprelude's Avatar
Default Re: (ImPuLsIvE)
yes if they were aligned on a machine with runout measurements it will tell if the rim is bent, also road force tests would show if a tire is bad. as long as you trust your friend then i would say wheels/tires are ok. i believe your issue lies in the alignment or suspension component getting ready to go, that was not noticeable with the smaller and i'm sure lighter wheels.
Old May 12, 2006 | 12:18 PM
ImPuLsIvE's Avatar
Turns out the company I purchased the wheels from sent me the wrong Hub Centric Rings. They're certain the news ones will solve my issues. I'll keep you all posted
Thanks for the feedback/help guys!!
Old May 16, 2006 | 02:49 PM
ImPuLsIvE's Avatar
The hub centric rings weren't the problem
Seems my car is to blame.. Which is one hell of a coincidence if you ask me.
So it could be one of 3 things.. CV joint, Wheel Bearing or Tie rod. I'm bringing my car to a Honda Specialist later this week, as I don't have the time to check the car myself.
Hopefully this won't cost me a ton. I wouldn't want my engine/turbo project to be delayed cuz of this crap
duwa
Oct 26, 2011 08:19 AM
LudeJdm
Jun 12, 2007 05:31 PM
Vouthanack
Jun 15, 2004 05:46 PM
jdmstreethatch
Jan 11, 2004 04:28 PM
JDC2
Nov 24, 2003 10:32 AM
