Radiator fan??
Old May 11, 2006 | 11:17 AM
Lan's Avatar
Lan
Default Radiator fan??
I want to know if anyone knows how to make the fan run after the car is turned off. Friends of mine had electric fans installed back in the day on their 4x4's. My engine gets hot so I plan on getting a new thermostat switch. Any ideas? Has anyone done this before? Thanks in advance.
Old May 11, 2006 | 11:52 AM
skunked's Avatar
Default Re: Radiator fan?? (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">I want to know if anyone knows how to make the fan run after the car is turned off. Friends of mine had electric fans installed back in the day on their 4x4's. My engine gets hot so I plan on getting a new thermostat switch. Any ideas? Has anyone done this before? Thanks in advance. </TD></TR></TABLE>
I'm sure you can hook it up to some sort of delay module.
Old May 11, 2006 | 11:58 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Radiator fan?? (skunked)
My 91 Accord DD does that. Not sure why/how. You could hook the fans up to a switch so when you turn off the car, you flip the switch and the fans turn on. Of corse you would have to sit there untill you wanted them to stop and flip the switch again.
Old May 11, 2006 | 12:04 PM
skunked's Avatar
Default Re: Radiator fan?? (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">My 91 Accord DD does that. Not sure why/how. You could hook the fans up to a switch so when you turn off the car, you flip the switch and the fans turn on. Of corse you would have to sit there untill you wanted them to stop and flip the switch again.</TD></TR></TABLE>
ah yes, accords do that....hhhmmm
I wonder if a turbo timer would do this as well?
Old May 11, 2006 | 12:25 PM
Lan's Avatar
Lan
Pretty good question no?
Old May 11, 2006 | 12:32 PM
Lan's Avatar
Lan
Now that I think of it there must be an aftermarket fan switch that has something built in which enages the fan when the temp is over normal operating temp regardless if the engine is on or off. I know they are available for old toyota trucks (at least my friends had them) .
Old May 11, 2006 | 12:54 PM
skunked's Avatar
http://store.summitracing.com/...w=sku
Old May 11, 2006 | 01:08 PM
Lan's Avatar
Lan
Nice.... Isn't that a little hot though??
Old May 11, 2006 | 01:47 PM
skunked's Avatar
they make more than one
chellerfl
Jul 13, 2016 07:43 AM
asoRm
Aug 13, 2014 12:10 PM
thisdamnhonda
21
Feb 26, 2012 09:47 AM
drew_kousk
13
Jun 28, 2008 03:54 PM
MattsGreenEG
Mar 10, 2007 04:23 PM
