HELP!--- Transmission/Clutch problem----HELP!
Old May 10, 2006 | 10:45 PM
nostreble's Avatar
Default HELP!--- Transmission/Clutch problem----HELP!
i just installed an s1 tranny and replaced the clutch to a stock one. it went into all gears with no problems when the car was off. When i finally started the car, i couldnt get it into any gears. i learned that in order to get into first gear, i would have to let the clutch pedal up and it would get in. after i got into first, everything else seemed alright except when i try to downshift to 2nd at regular speed it wont go in. anyone know what may cause this???? thanks in advance
Old May 11, 2006 | 06:06 AM
nostreble's Avatar
Default Re: HELP!--- Transmission/Clutch problem----HELP! (nostreble)
Old May 11, 2006 | 08:32 AM
dandizel's Avatar
Did you adjust the clutch correctly?
Old May 11, 2006 | 12:35 PM
nostreble's Avatar
Default Re: HELP!--- Transmission/Clutch problem----HELP! (dandizel)
adjusted it the best i can. . . .
niceprelude
Dec 29, 2008 08:35 PM
mr abstract
Nov 27, 2006 10:56 AM
2wheelhunter
Aug 30, 2006 07:32 PM
slowdaintegra
Dec 21, 2005 01:31 PM
C4wrx
Oct 18, 2002 02:17 PM
