obd0 hondata s2
Old May 10, 2006 | 08:38 PM
slow91crx's Avatar
Default obd0 hondata s2
i found a good deal on a hondata S2 and am considering getting it to run my mild built b18c1 in my crx. im still obd0 nad kinda wanna stay that way, im just curious if anyone has more info on the hondata s2 system so i can make sure it will work with my pr3 ecu and that i can get everything i need for it. any suggestions / links would be appreciated. also how much is one of these units typically worth?
thanks for ANY info people, i appreciate it!
Old May 11, 2006 | 04:46 AM
slow91crx's Avatar
Default Re: obd0 hondata s2 (slow91crx)
bump. i need help people
Old May 11, 2006 | 11:54 AM
sohcnyce's Avatar
u need to be odd1 to hondata
Old May 11, 2006 | 12:39 PM
slow91crx's Avatar
Default Re: obd0 hondata s2 (isphatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isphatch &raquo;</TD></TR><TR><TD CLASS="quote">u need to be odd1 to hondata </TD></TR></TABLE>
your are wrong. the hondata systems stage 1-4 were all the predecessors to the s100, s200.. they were designed to work with obd0.. if you don't have any correct/useful info then stay away
Old May 11, 2006 | 06:06 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx &raquo;</TD></TR><TR><TD CLASS="quote">
your are wrong. the hondata systems stage 1-4 were all the predecessors to the s100, s200.. they were designed to work with obd0.. if you don't have any correct/useful info then stay away </TD></TR></TABLE>
correct..
i ran hondata stage 3 on my built GsR with no problems...I still have it..just not useing it at the moment..
they typically run for about $100 ....
Just make sure your tuner supports it...Church had to read up on the hondata site when he tuned it but worked good, ***** ancient like my 88 hatch...
Old May 11, 2006 | 10:23 PM
bc_ef8's Avatar
Hondata Stage 2 with PR3 ecu here. It works but I recommend going OBD1.
Old May 12, 2006 | 04:46 AM
slow91crx's Avatar
Default Re: (bc_ef8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bc_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">Hondata Stage 2 with PR3 ecu here. It works but I recommend going OBD1.</TD></TR></TABLE>
why? i just want to tune the car so it will run safely, if all i would get out of obd1 would be launch controll and a couple more HP. then im not all too concerned.
95cxGSR
Jun 7, 2004 09:43 PM
Full-Race Henry
13
Dec 8, 2003 06:52 PM
hi mom
Sep 16, 2003 09:40 PM
The Early November
Jan 3, 2003 11:58 AM
7rrivera7
Nov 6, 2002 08:35 AM
