Question about suspension...
Old May 10, 2006 | 06:55 PM
Sleepy_Red_hatch's Avatar
Default Question about suspension...
Koni yellow sport and H&R race springs = STUPID LOW (especially for canada) so i was wondering, can you buy just the sleeve part, so i could mount my H&R race springs on an adjustable perch?
Old May 11, 2006 | 08:46 AM
Default Re: Question about suspension... (Sleepy_Red_hatch)
up?
Old May 11, 2006 | 10:23 AM
Sandmaggot's Avatar
Idk, try it...
Old May 11, 2006 | 10:24 AM
Default Re: Question about suspension... (Sandmaggot)
id try it if you could buy the sleeves...can you?
Old May 11, 2006 | 10:29 AM
EG6_GUY's Avatar
Not sayin you should do it, but Ground Control sells the sleeves and nuts for Konis. Who knows if the bottom inner diameter of the H&R is big enough to fit the nut.
I guess if you tried it and it did not work you could just order the springs from GC and complete the set up.
Old May 11, 2006 | 10:56 AM
Default Re: Question about suspension... (EG6_GUY)
what exactly is keeping those ebay springs onto the adjustable perches? can i seperate them from the perch and use that?
Old May 11, 2006 | 11:06 AM
EG6_GUY's Avatar
Generally, the bottom of the spring is somewhat flat to mate with the perch. And the inner diameter of the spring fits over the sleeve and the perch is as large or larger than the outer diameter of the spring.
There is also a cap(sometimes) that centers the top of the spring on the rod of the shock.
The Ground control setup is really the only sleeve type coilover that is made to fit the Koni properly/safely IMO.
Old May 11, 2006 | 11:17 AM
interesting but i've seen skunk2 sleeveovers on konis, as well as omnis...i dont know what to do...my car is way too low and im way broke
Old May 11, 2006 | 11:40 AM
Voyage34's Avatar
wouldnt suggest it because the lowering springs, with the stepped end coil wont sit properly on the adjustable perch. most lowering springs arent of the same diameter as the those found in coilover kits, i.e. ground control.
Old May 11, 2006 | 11:43 AM
dohcVTECeg2's Avatar
Default Re: Question about suspension... (Voyage34)
just put your h-r's on your stock shocks for now until you gather some money to fix the problem
Old May 11, 2006 | 11:57 AM
EH339's Avatar
I'd keep the Koni yellows over keeping the H&R springs on your car... I love the yellows and have done them first with stock springs and then ITR springs. Now I've paired them with the GC coilovers.
honda_k20a
Suspension & Brakes
Sep 21, 2009 06:41 PM
honisoto
Suspension & Brakes
26
Sep 22, 2008 01:30 PM
Lan
Suspension & Brakes
Mar 23, 2006 12:02 PM
opeth13
Aug 25, 2004 09:39 PM
deviant1
May 3, 2004 08:09 PM
