Clutch booster or clutch master clyinder problem
I drive a 99 prelude sh. Yesterday I was driving and the clutch lost pressure and feel all the way to the floor. I look at the master clyinder and the fluid was low so I added some and then it was fine. I didnt see any leaks near the master clyinder. I saw some fluid down near the clutch I think it is called the booster. How hard is it to change one of these things? Whatelse do I have to change. Thanks for the help!!!.
So you saw fluid in the engine bay by the brake booster(big black vacuum diaphram). Or did you see fluid on the inside running down the firewall from the clutch master cylinder.
Since you mentioned it was low, try to bleed the clutch system and go from there unless a leak was detected.
Edit: oh i think your talking about the slave cylinder( bolted to the front of the block)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">So you saw fluid in the engine bay by the brake booster(big black vacuum diaphram). Or did you see fluid on the inside running down the firewall from the clutch master cylinder.
Edit: oh i think your talking about the slave cylinder( bolted to the front of the block)</TD></TR></TABLE>
I saw some fluid near the firewall on the inside of the car. Near the clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EbpEm1 »</TD></TR><TR><TD CLASS="quote">
I saw some fluid near the firewall on the inside of the car. Near the clutch</TD></TR></TABLE>
It sounds to me like you are going to need a master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 »</TD></TR><TR><TD CLASS="quote">It sounds to me like you are going to need a master cylinder.</TD></TR></TABLE>
Replace the slave while you're at it.
sounds like the problem i had the other weekend.
fluid leaked through the master cylinder seals, along the piston shaft past the firewall, and dripped slowly into the carpet.
i replaced the master and slave, no more problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cgo_62 »</TD></TR><TR><TD CLASS="quote">sounds like the problem i had the other weekend.
i replaced the master and slave, no more problems.</TD></TR></TABLE>
About how much did it run for you to fix it?
Just got done replacing the clutch master cylinder and tried to bleed it but the clutch pedal still drops down. While bleeding it doesnt build any pressure at all whatsoever.
Just got done replacing the clutch master cylinder and tried to bleed it but the clutch pedal still drops down. While bleeding it doesnt build any pressure at all whatsoever.</TD></TR></TABLE>
I am thinking that the slave cylinder is gone and needs replacing. When bleeding the clutch I know it takes a long time. But when i was bleeding it didnt build up any pressure at all.
check the hard line(hard line going from master cylinder to tranny) if it have leak, because that what happen to my homegirl car, end up replacing the hard line and it work fine now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">check the hard line(hard line going from master cylinder to tranny) if it have leak, because that what happen to my homegirl car, end up replacing the hard line and it work fine now.</TD></TR></TABLE>
Thats fine. When i took off the slave clyinder one of ruber boots was ripped. Thats where the leak was
I am trying to bleed my clutch line but dont know what i am doing wrong. First to start off with my clutch doesnt have any pressure and it drops all the way to the floor. I got a bleeding kit from advance. A lil pipe and cup that is connected to each other. I connect one end of the hose to the bleed screw and the other end to the cup with fluid in it. Then i lossened the bleeder screw and pumped the clutch couple of times and next thing i knew my lil cup was full of fluid? What am i doing wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EbpEm1 »</TD></TR><TR><TD CLASS="quote">I am trying to bleed my clutch line but dont know what i am doing wrong. First to start off with my clutch doesnt have any pressure and it drops all the way to the floor. I got a bleeding kit from advance. A lil pipe and cup that is connected to each other. I connect one end of the hose to the bleed screw and the other end to the cup with fluid in it. Then i lossened the bleeder screw and pumped the clutch couple of times and next thing i knew my lil cup was full of fluid? What am i doing wrong?</TD></TR></TABLE>
Okay, I took the car to meinke to have the clutch bleeded. But know the car feels lke it doesnt want to go in gear. At times it doesnt even go into gear. What could this problem be?
From: Forced to leave Austin, TX for, Oklahoma, USA
Into any gear? or just certain gears?
I've got problems going from 2nd to 1st and going into R but all my others are fine. I'd like to get an answer too since we're on the topic.
that common i got problem sometime to go from second to first. just have to lift up the clutch a lil to go into gear.
i fix the problem by adjusting the clutch to catch a little higher
dem0nk1d
Oct 26, 2006 12:01 PM
gsr1289
Aug 22, 2006 07:11 PM
707EF8
Jul 29, 2006 08:09 PM
