No fuel and No spark after Mini me swap???
Old May 10, 2006 | 06:14 PM
PrestonCRX's Avatar
Default No fuel and No spark after Mini me swap???
So my car ran fine before i did the mini me swap now all of a sudden i have no fuel and no spark??? i checked all the grounds and checked the relay with 3 extra's i have laying around all worked in my spare car ..... check my dizzy coil and stuff seemed fine . i also checked my pm6 ecu to see if that was fried put my spare in still got nothing .... any thoughts lemme know
Old May 10, 2006 | 07:00 PM
PrestonCRX's Avatar
Default Re: No fuel and No spark after Mini me swap??? (PrestonCRX)
ttt
Old May 10, 2006 | 07:09 PM
nelsmar's Avatar
is the fuel pump priming? or are the injectors just not opening? it is turning over right?
Old May 11, 2006 | 05:50 AM
PrestonCRX's Avatar
Default Re: (nelsmar)
fuel pump isnt priming but its turning over.
Old May 11, 2006 | 08:31 AM
vegaskurt's Avatar
Default Re: (PrestonCRX)
Fuse #14, think its called alternator solenoid lock or something. Pull it out and look at it. That damm little fuse did the same thing to me, stranded me about 5 miles from my house.
Old May 11, 2006 | 11:51 AM
ALLMOTORCRX20's Avatar
Default Re: (vegaskurt)
you said you checked all the grounds. I had this same problem and I didnt have the ground that goes on the thermostat housing. You might want to check that one, you might have overlooked it. That is the ground for the ECU. Without that, it wont have spark or fuel.
Old May 11, 2006 | 01:50 PM
PrestonCRX's Avatar
Default Re: (ALLMOTORCRX20)
checked it,i'll check it again, maybe it didnt ground good enough? i know its probley a ground but its pissin me off anyone have a diagram of all the grounds lol man this is some bull spit lol
Modified by PrestonCRX at 5:48 PM 5/11/2006
Old May 11, 2006 | 04:52 PM
PrestonCRX's Avatar
bump
Old May 11, 2006 | 11:19 PM
project 2two9's Avatar
check all the fuses and relays
Old May 11, 2006 | 11:37 PM
downest's Avatar
Default Re: No fuel and No spark after Mini me swap??? (project 2two9)
I was having a similar problem... what is your exact setup?
Old May 12, 2006 | 06:08 AM
nelsmar's Avatar
sounds like the ground on the thermostat to me. double check it..... clena it up make sure its grounding wellllllll. i did myn while the car was on
ran a wire from the wires(wrappeda round them) and ran it around my car. ended up puting on hoodpin and heard it prime. found out it was the stupid thermo was to dirty : P
Old May 12, 2006 | 07:14 AM
PrestonCRX's Avatar
aight well its not the relays i checked them the fuses are good im going to check the the ecu ground and what not so i'll keep everyone posted
Old May 12, 2006 | 02:00 PM
PrestonCRX's Avatar
WELL I"VE DECIDED TO SAY F THIS ENGINE LOL AFTER A QUICK COMPRESSION TEST TO FIND OUT BOTH D SERIES ENGINES I HAVE ARE NOW JUNK!!!! tIME TO SWAP IN THE B SERIES
97booger
12
Sep 17, 2009 12:35 AM
ChilBlu92
14
Jul 30, 2009 08:30 PM
dan617
Feb 3, 2009 11:18 AM
slowassciv33
10
Jul 1, 2007 04:04 PM
DumpedSi
13
Nov 29, 2006 09:17 PM
