Where to buy rounds aluminum rings for velocity stacks?
Old May 10, 2006 | 06:05 PM
blueoval557's Avatar
Default Where to buy rounds aluminum rings for velocity stacks?
Hey all,
Dont start threads much, but figured someone here may be able to help me. I am in need of some sort of aluminum round circles to cap off a set of velocity stacks. I am making a pan that sits inside a hoodscoop, which is just below the top of the velocity stacks, but I dont want the stacks to flare out, but instead have a nice curve to them to direct the airflow into the stacks.
The stacks currently just flare outwards, so I need something to comeplete that flare, and come back down. I have seen a couple guys on here using velocity stacks that seem to already have the round ring already machined on the end of them. Anyone know where I can buy just the rings, or some cheap stacks that I can cut the top off of to use as the rings.
These are 3.125" velolcity stacks by the way if that matters....
Thanks!
Kyle
Old May 10, 2006 | 07:54 PM
jdm monkey's Avatar
Default Re: Where to buy rounds aluminum rings for velocity stacks? (blueoval557)
rossmachine.com
velocity-of-sound.com
you're welcome...
Old May 11, 2006 | 06:00 PM
Default Re: Where to buy rounds aluminum rings for velocity stacks? (jdm monkey)
Expensive as F**K! haha. Thanks a bunch though man! I appreciate it!
Kyle
Old May 11, 2006 | 07:55 PM
preveink's Avatar
you could do somthing like this if you wanted to
http://forums.vwvortex.com/zerothread?id=2517182
Old May 11, 2006 | 10:33 PM
jdlracing.com's Avatar
Default Re: Where to buy rounds aluminum rings for velocity stacks? (preveink)
that is an awesome idea!
Affordable too
For those who are too lazy to click the link, here are the pics.
Old May 12, 2006 | 12:20 PM
all_motor_mike's Avatar
Default Re: Where to buy rounds aluminum rings for velocity stacks? (jdlperformance)
yeah but where do u get the flare ended tubing at?
Old May 12, 2006 | 01:34 PM
Lamchop0000's Avatar
Default Re: Where to buy rounds aluminum rings for velocity stacks? (all_motor_mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">yeah but where do u get the flare ended tubing at?</TD></TR></TABLE>
i believe a muffler shop can do flares exactly like that.
Old May 12, 2006 | 07:37 PM
preveink's Avatar
the only problem is it is hard to flare aluminum i was having some flared from 1.5" to 2" and it kept splitting . they press it with a hydrolic press with a die of some sort
Old May 12, 2006 | 07:41 PM
Default Re: (preveink)
yeah i tried that a while back (just the pressing part to get a flare not from 1.5" to 2") with sch 40 aluminum and it was not happening. that stuff is way to thick to try and flare with out spinning it. i got a slight flare out of them but nothing extreme.
Old May 12, 2006 | 07:52 PM
L-CON1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preveink &raquo;</TD></TR><TR><TD CLASS="quote">the only problem is it is hard to flare aluminum i was having some flared from 1.5" to 2" and it kept splitting . they press it with a hydrolic press with a die of some sort </TD></TR></TABLE>try 5052!
The Si
Feb 17, 2007 03:03 PM
Bailhatch
Apr 29, 2005 08:25 AM
Spoon Si
Jan 29, 2003 08:44 AM
