HELP ON GSR WIRE HARNESS....
Old May 10, 2006 | 05:29 PM
pu5sipoppr's Avatar
Default HELP ON GSR WIRE HARNESS....
I'm doing a swap on my 96 GSR with a JDM GSR. My question is... Can I just use the USDM wire harness that I have and put that on the JDM motor? Or will there be any modifications that I will need to do? It's an OBD-2 JDM motor
Old May 10, 2006 | 06:50 PM
pu5sipoppr's Avatar
I've learned that I should use the usdm motor...But is there any mods I will need?
Old May 10, 2006 | 06:53 PM
SuzukaBlueAP2's Avatar
Default Re: (pu5sipoppr)
get yourself a USDM harness from the equivalent motor and you'll be fine.
Old May 10, 2006 | 08:00 PM
pu5sipoppr's Avatar
I also have the jdm obd-2 ecu with it. Do i need to modify anything on the ecu or the harness?
Old May 10, 2006 | 08:32 PM
SplitEagle's Avatar
It should work without modifcation since it is the same obd type and same car/engine
v1sion
Dec 11, 2009 03:04 PM
Jimmii
Apr 9, 2009 06:54 PM
WreckedTeggie
Feb 20, 2004 11:19 AM
