Suspension & Brakes Theory, alignment, spring rates....
Rear springs???
Old May 10, 2006 | 03:55 PM
Redsun's Avatar
Default Rear springs???
I have a question for regarding the way rear springs are made. Why are the coils so close together at the top? The front ones are not the same as th rear so why do they make it so the rear ones are closer together at the rear??
Old May 10, 2006 | 04:11 PM
Tyson's Avatar
Default Re: Rear springs??? (Redsun)
progressively wound in the rear. the spring rate changes dependent on how much the spring is compressed. generally better for comfort but still offers a higher spring rate at extremes.
Old May 10, 2006 | 04:15 PM
Redsun's Avatar
Default Re: Rear springs??? (Tyson)
so does that explain why the back is always higher than the front?
What if i cut like two coils at the top?
Old May 10, 2006 | 04:17 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun &raquo;</TD></TR><TR><TD CLASS="quote">so does that explain why the back is always higher than the front?
no, not really. i dont find the rear always higher.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What if i cut like two coils at the top?</TD></TR></TABLE>
youd lower the height of the spring and raise the spring rate.
Old May 10, 2006 | 04:20 PM
Redsun's Avatar
Ok, well i always find that the rear always higher than front for traction issues front stock to after market, or it maybe that i've took off so much weight from my rear.
So if i cut the top coils fromrear then i will experience a harser ride.
92integraVTECgsr
Mar 26, 2008 10:55 AM
jt-sport
22
Dec 15, 2005 07:10 PM
trooper0641
Mar 1, 2005 01:00 AM
D50boy
10
Mar 4, 2004 06:06 PM
blkgsr03
10
Nov 23, 2003 04:54 PM
