Viper 350HV question, autolock when arming. How to disconnect feature?
So Ive got a Viper 350HV and when you arm the system it locks the doors automatically for you. When you disengage the alarm the doors unlock. What I need to know is which wire to cut from the alarm brain so that the doors will not lock when arming the system.
Why you may ask. Because Im getting ready to paint my car and in the process of shaving the handles off. I see no need to have the doors lock once there's no exterior access.
On a side note, I already shaved the pass side off and knew about 2 wires that ran to the locks on that side and clipped them with success. Now when arming both sides wont lock. Sounds like the mission is accomplished, but I wanna make sure I nip the signal from the source to prevent any future issues.
Sorry for the long post, but does someone know what color wire I should cut from the processor? THX
On the brain, there's going to be a small white plug with a green wire and a blue wire. Unplug that. Those are the lock wires. I would just unplug it in case you ever change your mind.
Well, you're going to need to pop the doors now instead of the locks. So just move the door lock actuators onto the door handles.
You don't need to cut or remove anything. You can program the alarm feature using the valet. If you don't have the owners manual, try this: http://www.the12volt.com/uploa...M.pdf
sweet thanks. On a side q' do any of you know where I can get an extra remote for my system?
