ls t super afc settings
I have a turbo ls and im wondering wut good settings would be for the apexi super afc running about 7 lbs on the stock motor and injectors, if anyone has settings on their afc that work pretty well and get as much pull as possible i could use sum help....thanks
Unless your going to run higher fuel pressure the stock injectors wont be able to keep up and then if you do that, your fuel pump wont be able to keep up. Get some DSM 450s and a 190lph or better fuel pump, hook up a wideband 02, retard the timing a few degrees and have it tuned. You definetly should get bigger inejctors. People have pushed 7psi with a rising rate regulator and even more boost then that buy why risk it? If at all possible, get CROME or uberdata and have it tuned.
Blaze
Blaze
89dxhunchback
Jul 14, 2002 09:55 AM
Chip398193
Nov 19, 2001 10:55 AM
