LSD - 01 integra gsr
Old May 10, 2006 | 01:06 PM
bleezfome's Avatar
Default LSD - 01 integra gsr
im curious about how to put lsd in a car.. what are some dapandable tested brands from you nguys ... allk the help is welcome thanks ..
Old May 10, 2006 | 01:58 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: LSD - 01 integra gsr (bleezfome)
The OEM Integra Type R LSD is a good helical design.
Old May 10, 2006 | 02:07 PM
bleezfome's Avatar
Default Re: LSD - 01 integra gsr (Dogginator)
what is the price... and i know it increases stablility in both wheels... but does it prevent wheel bounce or what.. other than the powering the slipping wheel ?
bleezfome's Avatar
installation is difficult ?
Old May 10, 2006 | 02:12 PM
Dogginator's Avatar
Daisy... Daisy...
You can find a used one for about $300. The installation is somewhat difficult. You must remove everything (main shaft, counter shaft, shift forks, etc.) from the transmission to perform the installation. You also need to properly shim the differential.
There is a decent write-up here.
https://honda-tech.com/zerothread?id=795700
Old May 12, 2006 | 11:12 AM
bleezfome's Avatar
is it a substantial increase in traction in a stock gsr ??? just curious
Old May 12, 2006 | 02:38 PM
00IntegrAllmotoR's Avatar
HT Black OPs
I have a new one for 420 shipped, ITR LSD.
Installtion I would say a 7-8 out of 10
Old May 12, 2006 | 02:41 PM
RexShop's Avatar
What do you want to do with your car..?
Over the years... it seems to me.. I don't need a LSD... as of right now.. I just do straight line stuff....
Make note if you launch and go in a straight line.. you will leave two black lines.... soon as you turn the slightest bit.. it'll turn into a 1 tire fire.
So if you just go out every few weeks to the drag strip.. I think you're okay without an LSD.....
Although the above price is pretty darn nice.
shocker911
Transmission & Drivetrain
Feb 10, 2011 08:22 PM
mountaindewguy
Dec 10, 2005 06:16 PM
b18c195
May 23, 2004 06:53 AM
