96 honda accord suspension troubles, need sugestions
when i bought my car the front end was lowered, i have recently found out that the way they lowered it was by placing lowering springs with stock components....now my problem begins, i have stock suspension in the rear and a hybrid of stock and aftermarket on the front and the front suspension is failing...i need something new on at least the front...would you recommend going with an all around suspension system (changing both front and rear) or just changing the front into a fully aftermarket suspension and leaving the back as is...note the back doesnt have to be changed and i like the stance because it shows off my invidia REALLy well....or if you can recomend a good suspension kit that can be adjusted low in the front and high in the back I wouldnt mind putting time into that either
Go with all around might as well do a full job, not a half-S. (I bet your car handles like crap around turnes) Go with KYB AGX shocks and Eibach Sportline springs. Best bang for the buck!!!
