Is this the connector to reset SRS on a EG?
get better and several photos, doesnt have to be so close either.
all i know is i remove mine and i get the srs light, if i put it back in the light goes away.. so no need for me to reset anything. i have a 92 si hatch and it also did the same on my 93 cx that i had previous...
and both cars only have drivers side airbag no passenger side. so maybe the reset on eg only applies to two airbag 92-95 eg's ???
Same exact problem. I took this picture about an hour ago
95 VX:
I removed my stock seats and replaced them with GSR seats. I installed the civic's seat belt clip and now have the "SRS" light on constantly. I don't have a passengers seat in, but never had a problem when I rode with one EG seat.
95 VX:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">Same exact problem. I took this picture about an hour ago
95 VX:
I removed my stock seats and replaced them with GSR seats. I installed the civic's seat belt clip and now have the "SRS" light on constantly. I don't have a passengers seat in, but never had a problem when I rode with one EG seat.</TD></TR></TABLE>
the srs harness clip is the upper right yellow plug.(the yellow plug just above the ignition harness clip which is above the 15 and 10 fuses) the other lower yellow wire works with your horn system. and has nothing to do with the srs system. and its yellow due to the horn wiring being incorportated in the srs wiring loom,) and it will be very hard to take off it has a double snap of some sort. i removed it ....got a cell, put it back in cell went away. i also did this like i said with a 92 si hatch and a 93 cx both with no passenger side airbag, and i also had 98 integra leather seats in the 93 cx never a problem...
like i said not sure if the cell problem is due to only dual airbag cars, but i never had any resetting of my cell.
Modified by cxSHOE at 6:11 PM 5/10/2006
Modified by cxSHOE at 6:12 PM 5/10/2006
95 VX:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">
Yeah, I tried unplugging that harness and it just would not come out. I will try again in the morning.
My VX has dual bags
Thanks for the help
My VX has dual bags
Thanks for the help
My VX has dual bags
Thanks for the help
yea dont force it out. basically there is a grey housing around the clip which need to be snapped opened and then the yellow harness itself has a snapping part...
My VX has dual bags
Thanks for the help
</TD></TR></TABLE>yea dont force it out. basically there is a grey housing around the clip which need to be snapped opened and then the yellow harness itself has a snapping part...
I don't know what the problem is....
With the keys out of the ignition I jumped the harness using the paper clip.
Turned the ignition to II (On) and the SRS light justs stays on.
Removed battery cable and tried the above again.... SRS light stays on
Any advice?
Any advice?
spoolinNpullin
May 12, 2009 07:00 PM
