front end conversion 98 converted to 99/00
Old May 10, 2006 | 06:09 AM
JDean6pac's Avatar
Default front end conversion 98 converted to 99/00
i wanted to do a front end conversion to my 98 honda civic and i was curious to know what are all the parts i will need and everything i need to convert it and does it jus bolt on?
Old May 10, 2006 | 06:14 AM
LyghtFunky1's Avatar
front bumper, 2 fenders, grill, 2 headlights, hood, & if your trying to be *perfect*, a 99-00 radiator support.
Old May 10, 2006 | 06:15 AM
oh, however.. you can drill holes in your current radiator support to have the bumper bolt up!
Old May 10, 2006 | 06:17 AM
JDean6pac's Avatar
Default Re: (LyghtFunky1)
alrite thanks again:D
Old May 10, 2006 | 06:54 AM
Ruben19's Avatar
you dont have to drill any holes.
the 96-98 radiator suppor will work prefect.
no mods required
Old May 16, 2006 | 05:18 AM
JDean6pac's Avatar
Default Re: (Ruben19)
so do i need the bumper supports or anything? i can jus bolt everything in? and the bumper will fit fine with th 98 radiator support?
Old May 16, 2006 | 06:17 AM
existanzcivicb20's Avatar
Default Re: (JDean6pac)
yes every thing is a direct bolt on I had no problems my self when I did it and it looks way better
Old May 16, 2006 | 06:24 AM
JDean6pac's Avatar
Default Re: (existanzcivicb20)
ok thanks much appreciated
Old May 16, 2006 | 08:15 AM
actually, if you want to attach the upper portion of the grill/bumper support to the radiator support to make a perfect bolt up, you *DO* have to drill holes... HOWEVER, you do not *HAVE* too, that is just if you are trying to go the extra mile for a perfect appearance swap.
supe's_civic
Aug 22, 2008 03:00 PM
JDean6pac
12
Mar 23, 2007 01:44 PM
mistaxjimbo
Aug 29, 2004 01:40 PM
DV98CVC
Sep 9, 2002 03:10 PM
Apr 10, 2002 09:38 PM
