what rods for an ITR
Old May 10, 2006 | 04:04 AM
jdmB18CT-R's Avatar
Default what rods for an ITR
I have a 97 jdmB18C-R with a Toda valve train and ill be installing a pct pistons kit. What rods will work well with my pct kit? Thanks much in advance!!
Old May 10, 2006 | 05:36 PM
jdmB18CT-R's Avatar
Default Re: what rods for an ITR (jdmB18CT-R)
ANYBODY??????
I really would like to know what rods will work best for PCT pistons rather than the stock ITR ones?
Old May 10, 2006 | 07:08 PM
tomlinson619's Avatar
eagle rods
Old May 10, 2006 | 07:15 PM
hypeR speed's Avatar
Default Re: what rods for an ITR (jdmb18ckid)
eagle rods won't work with pct pistons.... stock itr rods are fine for ctr pistons thas what im using 12.5:1 compression, no tuning 91 octane and no detonation... oem pistons use press-fit wristpins as opposed to eagle's which are floating type, and don't work together. I'd say oem itr rods are fine for your application unless your planning to go turbo, then you should go altogether with different pistons and rods
Old May 11, 2006 | 12:27 AM
jdmB18CT-R's Avatar
Default Re: what rods for an ITR (res09ggm)
thanks for the info!! So you wouldnt recommend changing the rods, not even to spoon rods? Do you drive your R regularly even though its a 12.5??
Old May 11, 2006 | 06:17 PM
yea its a daily driver, and i'd had it for about a week now, and still no problems, timing was retarded 2 degrees for safety, i'll probably get it tuned soon. as far as replacing rods, I don't think its necessary to replace them with spoon rods unless your revving to 9000 rpms 24/7. iirc they're just balanced oem rods. it all depends on your budget and what your plans r for your car. ask in the allmotor forum for more advice as far as engine work goes.
Old May 12, 2006 | 10:55 AM
Grand's Avatar
it would be worth your while to install arp rod bolts but thats about all i would do when going with pcts
ITRiWISH
Mar 10, 2008 08:12 PM
civicking99
10
Dec 24, 2007 06:18 PM
Capt. Jimbo McSubipants
Nov 22, 2005 03:50 PM
vtec69
Jun 17, 2002 09:41 AM
