FAQ: OIL IN SPARK PLUG TUBES (sticky?)
Old May 10, 2006 | 02:37 AM
92ehatch's Avatar
Default FAQ: OIL IN SPARK PLUG TUBES (sticky?)
I see this question come up more than once every day. Its definately a common issue with the accords and i think we need a sticky for it.
This link is for a cb7 (90-93) but same concept for the 94+
http://www.cb7tuner.com/vbb/sh...seals
The main writeup is on page 1, but if you look through it (page 2 or 3) they have a second writeup with pictures.
there are a couple of other sites around that have this info, if you have them available please post it in this thread.
Also, please get a helms/haynes/chilton manual for your vehicle, it helps, and you will want to use it.
MODS please sticky this, its asked way too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for oil in spark plugs returned 103 results</TD></TR></TABLE>
more info from P_Adams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">One of the disadvantages to having center mounted spark plugs is that they literally have to go thru the Valve cover to reach the head.
I don't see your year and model mentioned anywhere, so I'll have to make a generic illustration.
These are the Pieces you need (You get the idea)
VALVE COVER DETAIL: (5), (15) Gasket & Grommets
http://www.hondaautomotivepart...COVER
CYLINDER HEAD DETAIL (19) (ORING) (spark plug wells)
http://www.hondaautomotivepart...81%29
Hopes this helps
P
Modified by P_Adams at 2:30 AM 10/24/2005</TD></TR></TABLE>
Old May 10, 2006 | 02:55 AM
YeuEmMaiMai's Avatar
Default Re: FAQ: OIL IN SPARK PLUG TUBES (93cb7sedan)
put it in the 5th gen and 6th gen FAQs
Old May 10, 2006 | 02:58 AM
92ehatch's Avatar
Default Re: FAQ: OIL IN SPARK PLUG TUBES (YeuEmMaiMai)
how many people do you think search through that thing? its got alot of pages
if anything else, at least this thread will exist so the people who do search can find a post with just the link to the writeup.
Old May 10, 2006 | 05:07 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">put it in the 5th gen and 6th gen FAQs</TD></TR></TABLE>
Thats what I thought those threads would be good for when you first posted them, thats why I asked the mods if the 5th Gen could be a sticky (at the time only the 6th Gen was a sticky) but shortly after some random things were posted in there rather than all FAQ's.
What I think would be better would be a sticky just for links.
Inside, you would find links for 4th, 5th, 6th and 7th gen Accords as well as general links or just have the links seperated by Engine, Exterior, Interior, Suspension, ect.
This way, when someone does a write-up or finds a write-up, they can PM a mod and ask them to add "this" link to the FAQ thread. Then the mod would go into the thread and add the write-up to the correct area.
I don't like compairing forum to forum on this board but if you look at the 92-00 Civic forum, Prelude forum and the ITR forum you'll see they have FAQ threads stickied. Inside those threads you would find links to all sorts of things.
When I first got my 92 hatchback, I found the FAQ thread in the 92-00 Civic forum very helpful. It' put a lot of useful info right there in front of me. Things I needed to find out and others that were just good reading.
I think a FAQ stick with links to write-ups and other useful info would be a great idea for this forum but thats just my $.02
Old May 10, 2006 | 05:40 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: FAQ: OIL IN SPARK PLUG TUBES (TouringAccord)
This sounds reasonable, but I think we need to make some moderator changes for this forum first.
Old May 10, 2006 | 05:43 AM
H-T Order of Merit
Default Re: FAQ: OIL IN SPARK PLUG TUBES (George Knighton)
Cool
What moderator changes if you don't mind me asking? Is the Accord forum getting a new moderator?
Old May 10, 2006 | 06:01 AM
H-T Order of Merit
Accord Forum is falling behind.
Urbanlegend21 has only limited time to moderate, and his experience is with the 5 Gen mostly.
There's little information here about 6 Gen, and almost no information about 7 Gen, and this at a time that it seems a 7 Gen Accord is destined to win the STS Grand Am championship.
We need to get with the times a little bit.
Old May 10, 2006 | 06:08 AM
accord-pro's Avatar
http://www.hondaaccordforum.co...m.htm
here is another write up..
Ed ke6bnl
Jul 5, 2009 09:17 PM
CRZ1
Apr 26, 2009 08:59 PM
aznsk8er33
Jul 17, 2006 08:10 AM
crxaddikt
Aug 20, 2003 02:25 PM
-Trinitron-
Jul 11, 2003 04:26 PM
