HELP! cluster speed/rpm don't work, and is not a broken cluster
so at first i thought i had a broken cluster, the speed odemeter, and the rpm odometer didn't work, but the fuel, hot/cold, and everything else worked. I thought it was a broken cluster but then i traded someone another cluster and my still didn't work and hav da same problems, and the cluster i gave him was working fine.
so i need to know, what other possibilities is that my speed/rpm don't work?
check the meter fuse under the dash to see if it is blown, that should do the trick, same thing happened to me, if not then i dont know
DatOneGuy
20
Jan 25, 2015 10:45 AM
siregcivic
Oct 10, 2011 10:43 AM
civiccpedx
May 18, 2007 06:56 PM
