Which axles to go with? 350-400whp street DA
pretty much what title says, i just wanna see what you guys think is a good axle thatll handle 350-400whp reliably on the street along with the occasional drag days, I'm pushin almost 300whp now and sick of axles clickin and braking every few weeks. thanks
dood do a search there are plenty of people that have have made big hp and have gone mid 10s on stock axles. i would look into the cause of ur axles breaking.
at your power level, stock axles should hold up. i went 10's with stock axles, just pre-load like a ****. make sure you have a good clutch that wont slip or just buy axles, up to you.
problem isnt with the axels... i have stock type r axels and have well over 550whp... i launch at 5500 with a two step pre staging... your motor mounts and tranny mount is the problem... thats it... stock axels are fine for your power... make sure your axels are not at an angle... is your car significantly lowed? if you axels are not at an angle then your mounts are ****...
turboman
Feb 20, 2006 11:40 PM
