Does anyone make a 4" 3 bolt exhaust flange?
Old May 9, 2006 | 11:09 PM
*Boostwerks*'s Avatar
Default Does anyone make a 4" 3 bolt exhaust flange?
The largest I can find is 3". Really the only 4" flange I can find is a V-band, which is a little more $ than I'd like too spend.
TIA,
Bryson
Old May 10, 2006 | 12:31 AM
turbotommy's Avatar
Default Re: Does anyone make a 4" 3 bolt exhaust flange? (Bryson)
contact Allied Exhaust located in Mesa AZ.
google that ish
Old May 11, 2006 | 12:07 AM
HiProfile's Avatar
Default Re: Does anyone make a 4" 3 bolt exhaust flange? (turbotommy)
Depends on how many you need, your finish quality, etc. When I got my flanges waterjet'd, it came to $18 per flange (12 flanges, my CAD files, friend of a friend deal). If you made your own cad file, I would bet a place with an automated plasma cutter could do it for cheap.
Old May 11, 2006 | 10:08 AM
locash's Avatar
Hell, you're spending the loot for a 4" exhaust, might as well v-band it.
Old May 11, 2006 | 10:30 AM
TurboJesse
Guest
Posts: n/a
Default Re: Does anyone make a 4" 3 bolt exhaust flange? (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Hell, you're spending the loot for a 4" exhaust, might as well v-band it. </TD></TR></TABLE>
I agree..allows for easier fitment, and really not much more $$ If someone paid $18 as hookup price, and 2 flanges are needed for each connection thats $36 vs. $50 for a vband assembly.
Old May 11, 2006 | 01:44 PM
Where can you find a 4" V band assembily for 50 bucks? Is that including 2 flanges?
The best price I've seen is about 19 for the clamp, and 36 each for a flange. So that comes out to be about 90 bucks.
Old May 11, 2006 | 07:13 PM
Wideopentuning's Avatar
Default Re: (Bryson)
I believe ATPturbo.com has them
Old May 11, 2006 | 07:24 PM
1990crxsir's Avatar
I am an engineer at a medium sized manufacturing plant with two plasma burn tables. I am the one who draws wild stuff up on AutoCad and then writes the programs to send to the plasma table. I do personal work all the time. If you need flanges I can make them for you. In fact if you have any other needs that would be best done on a plasma table just let me know. Depending how thick you want the steel I could probably charge no more than $10 a flange plus shipping. Just let me know. Also if you need any other items burned out.
Old Jun 19, 2006 | 11:22 AM
DaveF's Avatar
Default Re: Does anyone make a 4" 3 bolt exhaust flange? (1990crxsir)
http://www.youngsperformance.com cheapest vband **** i've seen.
Boilermaker1
Welding / Fabrication
May 30, 2007 02:02 PM
ezmoneytrg
Nov 1, 2006 10:37 AM
david@didrace.com
Dec 7, 2004 06:01 AM
@irborne
Oct 21, 2004 10:13 AM
