obx cams on my setup
Old May 9, 2006 | 08:02 PM
turboant's Avatar
Default obx cams on my setup
here my setup
b18c1 motor with type r piston and a b16 head kms dule valve spring and retainer and my ??? is will obx stage 3 cam work with this set up or will it be to much. i was told that the valve will hit the piston is this tru.
and i have aem cam gares
Type: Stage III
Part Number: 10116
Lift/Duration: IN. 0504, 270; EX. 0.465, 279
Notes: Valvetrain upgrade required
Old May 9, 2006 | 08:29 PM
lohatch's Avatar
Default Re: obx cams on my setup (turboant)
stay away from those camshafts. do some reading. they'll eat your rockers
Old May 10, 2006 | 08:12 AM
turboant's Avatar
Default Re: obx cams on my setup (lohatch)
i already have them and some people have them with no problems
Old May 10, 2006 | 09:07 AM
Runnerdown's Avatar
good luck with those cams
have you considered actually claying the motor or checking clearances. Has the head been milled, block decked? head gasket? you cannot just post the cam specs and have a sure answer on if it will be safe or not. thats how motors get blown/ valves get bent.
Old May 10, 2006 | 09:13 AM
silverEG6's Avatar
true i had a set..in mine to test out in 1500 miles they ate my **** up had to get a new set of rockers for my car... stay away... look them on here, it would be a better investment to get your refund and save a bit more.. cause rockers arent cheap
turbob18si
50
Aug 22, 2014 07:50 AM
ef-hatchcrap
13
Mar 10, 2010 10:28 PM
psegs80
Dec 14, 2006 01:00 PM
ekblacknight
Oct 25, 2005 05:46 PM
kwik93si
May 2, 2003 03:58 PM
