Crx Sounds Like A CHOPPER!!! Why? No power, Fresh Rebuild. Exhaust sounds way to choppy
Old May 9, 2006 | 08:00 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Crx Sounds Like A CHOPPER!!! Why? No power, Fresh Rebuild. Exhaust sounds way to choppy
I just rebuilt this motor in my crx, d16a6 motor with vitara pistons and eagle rods, built head (used and known good)
Just got it running and tok it for its maiden voyage tonight, running a xenocron turboedit basemap, dsm 450's and a 3" open d/p
The tach doesnt work so i dont know where its idling at but its a little higher than I think it should be. It idles like a bag, exhaust just counds choppy, like theres a small time gap between each pulse, like a harley and the motor shakes a good bit (but I have hard motor monts)
SO I say expletive it, I think ive got the firing order just fine, new ngk ordinary spark plugs, ngk used wires that are known working
I jump in the car, everything is fresh (including the 6 puck clutch), the clutch was tough as expletive to creep out of the driveway, stalled twice.
But when your driving its just choppy as expletive, no power really, car wasnt going anywhere fast anyways, like a normal person would accellerate I guess ( i wasnt stomping it but I did see the boost gauge go to 3-4psi )
I can get a video tomorrow but itll probably be to loud to hear anything
I need to know how to diagnose this and how to fix it. I want to get tuned friday, and this aint running like a basemap motor I think should
Old May 9, 2006 | 11:56 PM
PINKS's Avatar
Default Re: Crx Sounds Like A CHOPPER!!! Why? No power, Fresh Rebuild. Exhaust sounds way to choppy (PINKS)
I dont think its the tune though, it just runs so dam bad, i'' have video of it tonight, gonna grab spark plugs after work just cause there cheap ones and i reused them
Old May 10, 2006 | 02:25 AM
Syndacate's Avatar
actually sounds like ur sucking air through the tb or im, hope those spark plugs work tho O.o
Old May 10, 2006 | 02:30 AM
PINKS's Avatar
Default Re: (Syndacate)
steady -14 on the vacuum gauge
Old May 10, 2006 | 02:59 AM
Suck my DX's Avatar
Default Re: (PINKS)
is the timing correct?
Old May 10, 2006 | 04:15 AM
99CivicSiBrian's Avatar
B A N N E D
Default Re: (Suck my DX)
I would rxpect to find that the cam timing is off slightly.
B
Old May 11, 2006 | 02:31 AM
Syndacate's Avatar
Default Re: (99CivicSiBrian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicSiBrian &raquo;</TD></TR><TR><TD CLASS="quote">I would rxpect to find that the cam timing is off slightly.
B</TD></TR></TABLE>
Yea, if it's not sucking air, then it's probably the timing that's off a tooth...but for some reason I think u already checked that out and it's fine..
ONly other thing I can think of is put in a stock ECU and see if it runs fine (borrow one from a friend or something..)
Cidone
15
Sep 1, 2007 12:05 AM
PINKS
May 11, 2006 07:27 AM
EG6[B16A1]
Oct 31, 2003 07:43 AM
